Central locking pump or recoding keys ?
Med performance Mar 10, 2012
  1. Med performance
    Med performance New Member
    My 2 keys have decided to stop working, replaced the batteries Still don't work ? The doors will lock with the button on the drivers door does that mean the pump is ok or still faulty ? Do the keys need to be recoded if so can it be done at home in the ignition with different button presses or dealer
  2. Jonesy321
    Jonesy321 New Member
    Have you checked the fuses? They are F6, F14, F37, F38, although in my own experience the problem is probably the shattering of the graphite impeller inside the pump itself, which sounds bad, but it really is a pretty easy fix. You can either source a new graphite impeller, or do what I did and just replace the motor inside the pump, also doing this means that you do not have to reprogramme the keys. The motor can be found here: [h=1]AUDI CENTRAL LOCKING PUMP REPAIR KIT 8L0 862 257 | eBay[/h]
  3. moredoor
    moredoor Member
    160
    If both doors lock using the inside button on the drivers door then it sounds like the pump isn't at fault.
  4. aragorn
    18,579
    868
  5. s3-oz
    s3-oz Member
    54
    I has an issue with my central locking mate and I found a how to on ehow.com and that worked where everything else didnt. I posed the link in another thread.
  6. Med performance
    i tried the ehow one but it says press the door lock button with the ignition on but the door lock button only works with the engine started, the pump just makes a noise with just the ignition on could it be shagged ?
  7. s3-oz
    s3-oz Member
    54
    Can't remember how it worked mate, but I can honestly say I tried EVERYTHING else and nothing worked. Tried this, and actually got to I think the 4th step and being a numpty couldnt see any lights that were meant to flash (I was in the car so obv didnt see the parking lights haha) and I ignored it got out and went into Tesco's, came back out and pressed the button for some strange reason and BAM the central locking was working :)
  8. Danio
    Danio AUDI-MANIACS.COM
    214
    22
    put one key into ignition and turn but don't start the engine.
    Then come out of the car and using another key close the door using key. After 2 sek press open button.
    It should work.
  9. Med performance
    Do u turn the ignition on till all the lights come on the dash which I think is 2 turns or just one with no lights ?
  10. aragorn
    18,579
    868
    Lights on.
    Did you not read the link i provided to these instructions on Rosstechs wiki?
  11. Med performance
    Sorry I thought it was only vagcom
