Central locking pump help
floyd 1.8 turbo Sep 9, 2009
  1. floyd 1.8 turbo
    floyd 1.8 turbo Mirror, Signal, Outmanoeuvre
    632
    Evening all, i've been told today that my central locking pump is not the right one for my car. Its one without a reciever so it cant pick up a signal from my keyfob which means i have to annoyingly use the key in the lock. Does anybody know how many different pumps there are? My part number ends in H, i've found one for sale with the part number ending in J. Will this be any good to me?
  2. aragorn
    18,485
    855
    H should be a remote capable pump as far as i'm aware.
  3. floyd 1.8 turbo
    632
    Well according to Tim at 'the phirm' its not the right one and he knows his stuff!! He's tried coding the key in the lock, buying a new battery for the fob and plugging in his laptop to my car. The part number on the pump does not match with my chassis number so it must be wrong?
  4. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    you will need an 8L0 862 257 'G' and you will need to add an aerial as it didnt leave the factory with remote locking so range will be very poor
    more info here
    http://translate.google.co.uk/translate?hl=en&sl=da&u=http://www.audiclub.dk/forum/viewtopic.php%3Ff%3D61%26t%3D5371&ei=zNlJSrjENMKgjAe1u-Ri&sa=X&oi=translate&resnum=8&ct=result&prev=/search%3Fq%3D8D0%2B862%2B257%2Bremote%26hl%3Den%26sa%3DN%26start%3D10
    never come across a 'J' pump
    8L0862257 early remote pump with limited functions e.g wont operate door flashing led's
    8L0862257 'A' early non remote pump
    8L0862257 'H' later 98-99 non remote pump
    8L0862257 'G' later remote pump for use with 2 button fob
    8L0862257 'P' + 8D0862257 'E' facelift pumps for use with 3 button fob,
  5. aragorn
    18,485
    855
    interesting, i thaught everything after C did remote locking.
  6. floyd 1.8 turbo
    632
    Thanks for all the help, Audi wanted £277 for the pump, the scrap yard wanted a tenner! You can guess which one i went for!
    Thanks again gents
