central locking kit problem
daz616 Dec 6, 2010
  1. daz616
    daz616 Member
    37
    I brought a central locking kit of ebay as my b5 dosent have remote locking,reading through the intructions there are 4 different ways of wiring it to the lock,
    1,negative trigger
    2,positive trigger
    3,pos/neg trigger
    4,pneumatic lock
    any idea of what the a4 b5 saloons are fitted with even better if anyone has a wiring diagram thanks in advance
    cheers
  2. pjw
    pjw Member Audi A4
    222
    I was always under the impression that they are all pneumatic, powered by a pump.
    Whats the link off ebay and ill have a look?
  3. daz616
    daz616 Member
    37
  4. aragorn
    18,036
    725
    You want to use negative trigger iirc.
    I can look out the diagrams tomorrow for you, you'll need to tell us what exact model/year you have though
  5. daz616
    daz616 Member
    37
    that would be great it's a P reg 1996 2.6 se saloon cheers
  6. pjw
    pjw Member Audi A4
    222
    I cant really see the photos to be honest, i can imagine from the ebay listing you somehow have to wire it to the horn feed and the indicator feed - which i imagine can be a bit of a nightmare. It might have worked out cheaped and easier just to get a central locking unit from a facelift b5 with remotes.
    Either way it shouldnt be hard to wire in. What are the instructions like? I quite fancy remote central locking but dont fancy splicing the a4s loom to do it..
  7. pjw
    pjw Member Audi A4
    222
    From looking at another universal kit you would have to get some scotchloks to make life easier and splice into the wires going into the remote central locking control unit. You would then have to run two longer wires if you want to splice into the indicators.
    You would have to work out which wire is which at the plug on the central locking control unit first though, ie + feed, ground, open and close command.
  8. daz616
    daz616 Member
    37
    i was just going to leave the indicator and horn out only really want the central locking
  9. aragorn
    18,036
    725
    sorry about this i totally forgot about it.
    Indicators you can just pickup at the rear light clusters. I didnt bother with a horn connection.
    From what i can tell, you want grey/white wire on "A/3" to unlock, and brown/grey wire on "A/4" to lock.
    Negative trigger.
  10. pjw
    pjw Member Audi A4
    222
    Are the above wires accessible at the central locking module? Im also tempted to get one of these kits.
