Central Locking Help
finesse Sep 27, 2011
  1. finesse
    finesse Active Member
    2,805
    What does this button on the pillar do?
    Finally, any usual reasons why the alarm goes off every time I lock it?
  2. a3tdi2001
    a3tdi2001 Member
    437
    It turns of the interior motion sensor so that you can lock the car and the alarm won't be set off by a dog or a wife if they are still inside. Could be the batteries in the alarm siren, does it ever give four short pips when you go to start it?
  3. finesse
    2,805
    No short bleeps when first started.
    S3's are a cu nt of a car to own
    Going to try this with no tools
    Waks Wide Web
  4. a3tdi2001
    a3tdi2001 Member
    437
    Well if it is the siren, removing it will allow the system to work normally with the immobiliser still doing its job. You'll need a ten mil. spanner to undo the nut on the back of the siren, should be one in the tool tray? I found it easier by slipping the foam casing off the central locking pump and disconnecting and taking it out to give a bit more room.
  5. finesse
    2,805
    Thanks for your help fellow ASNer
    Quick scan -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01134 - Alarm Horn (H12)
    49-10 - No Communications - Intermittent
    Address 37: Navigation Labels: Redir Fail!
    Part No: 8L0 035 192 G
    Component: RNS 4.1 H06 BNO 0017
    VCID: 2F68B351C78D
    No fault code found.
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00000
    VCID: E0CA806D4AD3
    1 Fault Found:
    01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
    35-00 - -
  6. Danio
    Danio AUDI-MANIACS.COM
    214
    22
    I got the same problem m8 And I can not do anything about it.
    All what I did was I switch off the alarm using vcds.
    Anyone have better idea what to do??
  7. aragorn
    18,137
    765
    Clear your codes, then wait until the alarm goes off then rescan.
    That way you should only have one "Alarm Triggered by" code which tells you what set it off.
  8. Danio
    214
    22
    That will not help!!
    Done it several times
    Only when I switch alarm off using vcds the faults will not came up.
  9. finesse
    2,805
    Aragon, any idea about this?
    Alarm triggered by Anti-Theft Sensor; Rear right
    Location?
    Had a moment where the key in barrel didn't lock the car + central locking not working
  10. Danio
    214
    22
    It is alarm sensor on right side located behind post trim between door and back window. Maybe wire is just unplugged.
    Your central locking pump could get wet so it is the time to have a look it.
