Central Air Vents Not Blowing Air
silversurfer Sep 12, 2010
  1. silversurfer
    silversurfer Member
    223
    Hi,
    Has anyone had any problems with the 2 central air vents not blowing air through, I've tried the climate unit on hot and cold and it makes no difference, still no air blown through :huh:
    The vent on drivers side and the far passenger side work fine.
    Neil
  2. Xmay4444
    Xmay4444 On Point!!
    258
    Is the A/C unit on Auto?
    If it is then that is the probable cause as the Climate control automatically adjusts the air flow to keep the cabin temp at the set value.
    Try increasing the fan speed (which will disable the Auto), and then press the middle vent switch and see if air comes out the middle vents. If the air does come out, then you have no problem with those vents.
  3. silversurfer
    silversurfer Member
    223
    Cheers I'll give that a go on the way to work tomorrow.
  4. quattrojames
    14,050
    578
    Its probably a motor/mechanism problem similar to the one detailed in THIS thread.
