Census 2011! How are your *standard* rods?
metricspaces Feb 13, 2011
How are your rods?
Poll closed Feb 20, 2011.
  1. Rods have NOT bent - on standard map.
    37.8%
  2. Rods have NOT bent - on stage-1 map
    37.8%
  3. Rods have NOT bent - on stage-2 map
    12.2%
  4. Rods have NOT bent - on higher than stage-2 map
    6.7%
  5. Rods bent :-( - on standard map
    0 vote(s)
    0.0%
  6. Rods bent :-( - on stage-1 map
    3.3%
  7. Rods bent :-( - on stage-2 map
    1.1%
  8. Rods bent :-( - on higher than stage-2 map
    1.1%
  1. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I personaly carn,t see what harm its doing, there are a lot more pointless threads kicking about....
    and you certainly can ignore it if you wish...
    It would be nice to get a few more different tuning companys giving their point of you.....Nick? ...Mike...awsome?
  2. AwesomeMike
    AwesomeMike Member
    165
    This is what I have seen in my time at a Dealership and tuners:
    1.8 20VT 225 engine:
    Standard BHP on a 225 - Bent Rod
    Mapped BHP on a 225 - Bent/snapped Rod
    Big Turbo BHP on a 225 - Bent/snapped Rod
    In short, you could just be really unlucky and have a 'weak' rod from factory...
    But in greater depth on the 225:
    Stock tuning is very unlikey to have a rod issue
    Mapped tuning is very unlikey to have a rod issue
    Hybrid K04 with as many bolt on bits and tuning I have seen this to bend rods, this was from when I worked at another tuner and I think in total I re-call around 3-5 have this issue.
    Anything over 330-350bhp (same ish torque) could do with a rod replacement, but this could depend a little on turbo set up:
    For example I know of a lot of IHI turbo kits at over 330bhp with no rod issues but cars with a GT28RS with around 330bhp have rod issues.
    Just my 2ps
    But as mentioned.... you could just be unlucky :(
    Mike
  3. badger5
    9,507
    2,003
    IHI's dont produce big torque, unlike their garrett counterparts...... one potential reason.
    heavy breathing engines, injesting their own oil fumes, causing high CF's det, unknown to the owners is a very likely causal factor imho.. 80k-100k+ milage on a lot of these now.. well "used".
    High timing pull, poor octane fuel (effective from oil fume) can combine to make from some serious cylinder pressures, which will bend/snap rods. Nothing to do with the tune or remap, just wear and tear.
    when these cars were new, the maps were written, they're older now, and what worked on fresh components is posisbly not as appropriate now, without checking and logging once done, to be sure whats going on. (dyno + logging etc, before and after....)
  4. shanejess
    shanejess Guest
    i was told years ago the bam engine had the strongest rods of the many 1.8t formats, is this true does anyone know.
  5. JS1500
    JS1500 Howdy
    1,166
    10
    I hope so!
  6. aragorn
    18,442
    846
    The rods are identical to every other 20mm rod fitted to 1.8T's, and are also the same as the rods fitted to most older 058 block engines, such as the mk2 golf 16v etc.
  7. s3dave
    10,110
    736
    Well come on tuners.....share your experiances.........thanks mike....
  8. frenno
    frenno Member
    34
    Rods have NOT bent - ON AMD STAGE 1, Garrett GT28RS
    * What stage map they were on e.g. stage-1, stage-2 - STAGE 1
    * What map they were on e.g. CustomCode, Revo, etc. - AMD
    * What max bhp they had - APPROX 300+bhp
    * What max torque they had - ?????lb/ft Tq
    * How old the car was - 1991 Golf Gti with a 2000 APY S3 Engine
    I've only driven it 50 miles so I may need to update this....
    APY 20v Mk2 Garrett GT28RS. IT PASSED!!!! Got an MOT and Tax disc today!!! - Club GTI
  9. Westy
    Westy Well-Known Member
    17,443
    1,104
    I'm about to go Revo stage 2 on standard rods but I'm hoping to get it mapped with a comfortable amount of torque. I'll let you know how it goes.
  10. Sandip
    2,456
    99
    Hope it all goes well, aslong as everything else is healthy then the risk will be lower i guess, i know if i had choosen Revo stage2 then my chances of bending a rod would have been very high because of my fuel pump struggling to maintain pressure after 5k
  11. Westy
    17,443
    1,104
    Well I'm getting it done by Bill so I'm sure he'll pick anything up that needs addressing. Fingers crossed.
  12. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    Just wondering sandip, why do you think a weak fuel pump would have increased your chances of bending a rod.
  13. Sandip
    2,456
    99
    Running lean on full boost and high rpm, more heat which with time may have taken its toll on my rods plus it's already done 130k lol
    To be honest though mine was running very lean when it was overboosting but luckily my egt's were low
  14. S3 Nattie
    1,599
    Aw ye, I remember your car was running really lean. I would have said myself that you would be less likely to bend a rod due to the mass within the cylinder being less.
    How is your car coming along anyway.
  15. Sandip
    2,456
    99
    Not bad thanks, needs to go back to get the map finished off. Need to get some logs done soon just to see how things are running
  16. superkarl
    superkarl MAN OF STEEL
    9,495
    2,436
    Logging sesh at awesome one evening?
  17. S3 Nattie
    1,599
    Good stuff. I havent read your build thread recently, will have a nose later.
  18. Sandip
    2,456
    99
    Funnily enough we had one on Friday night but we'll be having another soon, didn't get round to logging mine, are you going to DC11 Karl?
  19. superkarl
    9,495
    2,436
    What's dc11? Im really not familiar with the events meets and what not.
