CE module coding question
Khufu Jul 28, 2011
  1. Khufu
    Khufu Well-Known Member
    5,704
    31
    I recently update my 2003 8P A3's central electronics module to a 30 byte version. I've coded everything fine but there are a few new options I dont know what they are for:
    byte 8, bit 3 - interlock display via CAN instruments active
    and
    byte 23, bit 2 - internal turn light control algorithm active
    I'm guessing bit 3-4 are linked to bit 2
    any thoughts?
    Thanks.
  2. Dana @ Ross-Tech
    Dana @ Ross-Tech Member
    Post the scan clip from the old 09 module and the complete Auto-Scan with the new 30 Byte unit installed and I'll check it out.
  3. Khufu
    5,704
    31
    I had to rewire some of the electrics to use the new 09 module so swapping it back will be troublesome LOL. Its ok, everything is working fine, it was just in case you knew off the top of your head. Thanks.
