CD Error Problem
Rubber Duck Feb 13, 2012
  1. Rubber Duck
    Rubber Duck New Member
    23
    Hi Guys, Ever since I've had my audi I have always downloaded music on itunes and burnt to a cd to put in the car. Over the last few weeks I have occasionally been getting error 2 (cd unreadable) on the display, however now it simly will not read any of the CD's I have made. It will still read purchased CD's fine.
    Has anyone had the same problem or got any ideas on what might be causing it?
    Was thinking of trying a cd lens cleaner but never needed one of these ever so cant imagine it will do much good!
  2. A1DEYB
    A1DEYB Well-Known Member
    1,681
    43
    Yeah i have found this too using iTunes sometimes, all i do is burn them at the slowest setting possible or failing that burn them with Nero using it's burn audio CD function and always finalise the disk so it's been closed, ie no further writing possible to the disk.
  3. Rubber Duck
    23
    Aiden, do you burn as MP3 or as normal CD files?
  4. A1DEYB
    1,681
    43
    I download the songs as the MP3 file format then burn to the CD so it plays in a normal CD player IE non data MP3 compatible.
    10/4 Rubber Duck.
  5. Rubber Duck
    23
    The same as me then, I will try burning them again on the slowest setting. It just seems weird that I've never had the problem before.
    Audi gremlins methinks!
  6. A1DEYB
    1,681
    43
    Try using a different piece of burning software? Have you had a bash with Windows Media Player or Nero?
    First though i'd try the slowest setting burn.
    :icon_thumright:
  7. FranA3
    FranA3 FMDETAILING Regional Rep Site Sponsor Gold Supporter Audi A3 Team Brill Red
    7,246
    340
    Mine is doing exactly the same thing really annoying but it's doing it now with normal CDs
  8. AllThatGlitters
    AllThatGlitters Member
    93
    Same here - when mine does it sometimes makes the spinning noise when I turn the engine off for a few seconds.
  9. Rubber Duck
    23
    Set the burn to the lowest speed on itunes and it seems to have worked a treat. thanks Aiden
  10. A1DEYB
    1,681
    43
    No problem fella, glad it worked for you. :icon_thumright:
  11. FranA3
    7,246
    340
    What about when it does it on normal CDs tho do you think it needs cleaning or something like that
  12. gary3306
    gary3306 Active Member
    989
    41
    If you're having problems on bought CDs then I would say either you have an absolutely filthy laser, or the laser is knackered.:ohmy:
  13. FranA3
    7,246
    340
    its not all the time on bought cd's a rare thing luckily but still does it , hope its just a dirty laser , anyone know how i can clean it
  14. gary3306
    989
    41
    Best way is to slip the unit out of the dash (take any disc out first). Take the top off (about 4 screws) then use a cotton bud with meths on it and give the laser a good rub. You'll be amazed at the muck that comes off.
  15. FranA3
    7,246
    340
    yeah will do mate , i do play cd's everyday so won't be sup prised if there is loads of dirt on the lens lol
  16. Phil Worth
    Phil Worth New Member
    Did it work? I have exactly the same issue. Thx.
