cd changer wiring 2007 a3 with new hu
cjp2k Apr 6, 2007
  1. cjp2k
    cjp2k Member Team Tango Audi A4 S-line owners group saloon
    260
    23
    Hi guys, just got my cd changer cable and its got what looks like a ground cable thats seperate from the block... my question is where does this go on the quadlock connector or can i just ignore it??
    cheers
    Chris
  2. AndyMac
    9,832
    45
    If it's a ground cable then it needs to be bolted to the cars chassis. The changer should work without it but you may experience alternator whine/interference.
  3. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    if it is a longer brown wire than the other 8 then it is the earth. if you connect it to one of the bolts behind the head unit you should be in business. stick a ring connector on the end of the wire and put the bolt through the middle of it - that's what I did with mine.
  4. cjp2k
    260
    23
    Got it sorted, starting 2 think I had a duff changer as it wouldnt work, So I pressed one of the earth cables to the side of the headunit and it burst into life, SO i have clipped it onto the headunits body for now as I cant work out how to take pins out of the quadlock to do it properly!!
