Cd changer removal
gaz71 Jan 9, 2011
  1. gaz71
    gaz71 1.8T Quattro Sport AJL
    286
    Hi,
    Been having issues with my stereo throwing up random error codes when playing CD's.
    I want to remove the CD changer so that I can check it out mechanically and give it and the optical head a good clean.
    Had a look but cannot figure out how it comes out of the metal bracket that it is mounted in. :uhm:
    It's located in the boot.
    Can anyone give me any pointers as to how to remove the changer?
  2. aragorn
    18,607
    871
    On mine, the entire bracket slid out after removing 2 or three screws, then you can unbolt the changer from the bracket.
    Not sure if its the same on a saloon.
  3. tonya4
    tonya4 TDi Powerrrr
    408
    Remove the n/s boot trim,then undo 2 or 3 8mm bolts and the whole bracket comes out,after undoing the wiring plug.
    hth
    tony
  4. gaz71
    286
    Thanks guys.
    Got it out, now to perform surgery :)
  5. gaz71
    286
    Will an aftermarket cd changer fit onto existing wiring connection?
    Any recommendations?
  6. aragorn
    18,607
    871
    Mine had a panasonic unit fitted along with some really tatty wiring adaptor.
    It didnt work though, so i skipped it.
  7. tonya4
    tonya4 TDi Powerrrr
    408
    I got a factory changer spare from my avant,in full working order if you're after one.I will check and see if it will fit a saloon.
    tony
