CD Changer in Glove Box - Have you fitted a OEM one or ever removed one?
shaz Aug 30, 2012
  1. shaz
    shaz Member
    167
    As per title, has anyone ever removed or fitted a OEM cd changer that fits in the glovebox in a B6?
    I am currently trying to remove my glovebox but it seems as though it getting stuck around the cd changer area,
    so was wondering if anyone had removed one and where the fittings / screws were located?
    thanks guys
  2. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    You need the stereo removal keys to slide it out.
  3. VagCabby
    VagCabby Active Member
    513
    78
    As said you need some stereo tools to remove to changer but to remove the glove box its just 3 10mm bolts at the top under the door and two 10mm bolts at the bottom and it comes out with the changer still fitted
  4. shaz
    shaz Member
    167
    Hi guys, iv removed the bolts but it's still seems to be sticking,
    Should the glovebox slide out or does it need a bit of aggression?
  5. fallmonk
    fallmonk Turbo Sport
    1,868
    Was it not 5 x 8mm bolts holding it on ?
    was with mine ,
    3 top and 2 bottom .
    just remeber brut force and plastic dont go well together lol
  6. shaz
    shaz Member
    167
    thats what i dont want to do... brute force = something broken!
    yes they were 8mm bolts
  7. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    There's an additional bolt above the CD changer that you can only get at once you have removed the CD changer.
  8. shaz
    shaz Member
    167
    Thanks pal, I will have to find the removal keys to get to that bolt.
    Cd changer might be forsale If anyone is interested.
  9. VagCabby
    513
    78
    ah yes my bad, there 8mm bolts. As for the removal tools you can make your own, I took my radio out the other day to.fit my hands free kit and all I did was used an old Tesco club card, cut it to the width of the slot on the radio the cut and angle at the end so it was pointed and that did the trick, came straight out
