You should be able to see the connector on the end of the cable by removing the half panel -where the cd changer usually lives. If you look through the gap it should be clipped to the inner wheel arch, or at least mine is
Guys i m still having trouble with this cannot find or feel any un-connected cables around the wheel arch area. I attempted to remove the surrounding trim that supports the parcel shelf in but failed miserably cause it just did nt want to budge. HELP !
If you have an S3, you probably have a cd changer lead attached and from memory it is located in the left side cubby hole when you open the hatch. The cable should be clipped up somewhere by the sub amplifier.
