CD Changer and CD-Rs?
Chrismawa Nov 3, 2013
  1. Chrismawa
    Chrismawa Active Member
    457
    46
    I'm trying to play some CD-Rs I've burned in my Avant that has a 6CD changer in the dash but its just coming up with 'CD ERROR'...
    Surely a 2002 car can play CD-R discs??
  2. kanecullen89
    kanecullen89 Active Member
    569
    160
    43
    It should be able too. What make are the discs?
    I used asda discs once and they were such poor quality that they were slightly more transparent then ordinary discs. This caused a read error on my A3 8P. All other cd-r discs worked fine
  3. DieselJake
    DieselJake Well-Known Member
    2,838
    701
    Works fine for me, make sure it was writ as a CD disc rather than an mp3 disc (if you have 40+ tracks chances are it was saved in the mp3 format which the car can't read).
  4. cnut
    cnut Member
    153
    9
    CD-Rs should work fine as noted above. I cannot get CD-RWs to work at all though. Anyone else have similar problems? I have the Symphony II
  5. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    I had a few issues with mine when trying to play CD-R's (yes they were CDA format).
    I just purchased a used Symphony 2+ from a B7 A4 (my head-units dated 2008) - which was a direct fit with the aid of a Kufatec loom adaptor.
    Now I can load up with 6 MP3 CD's, experience better sound quality and get rid of the tape-deck which makes the car feel old.
    Cost me £125 last year - never looked back!
  6. cnut
    cnut Member
    153
    9
    How much better is the sound quality? I was looking at these earlier but I can't seem to find any for a low enough price.
  7. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Be aware also that the Symphony II+ uses a different antenna diversity system to the Symphony II so your radio reception will be worse (but not noticeable if you only drive in areas where the signal is strong) and you will get an antenna fault code stored.
