Cars got even worse!!! (with videos)
Mi11ar Feb 13, 2014
  1. Mi11ar
    Mi11ar Active Member
    316
    35
    Wouldn't a failed coil pack show up on diagnostics aswell? this hasn't? and were should I put the ignition amp?
  2. cammage08
    cammage08 Member
    171
    10
    Start the engine and unplug one by one... if it runs worse then thats ok if it runs the same then its probably that one..
  3. Mi11ar
    316
    35
    The spark plugs didn't feel right when I was screwing them in, I suppose it's possible they're not in correctly, but it's strange how 3 of the 4 are covered in sut and 1 isnt
  4. Mi11ar
    316
    35
    Already done this it's cylinder 2
  5. Mi11ar
    316
    35
    Can I buy 1 coil pack rather than 4? As I know which 1 isn't firing
  6. aviel131
    aviel131 Member
    104
    so replace cylinder 2 coil and you ready to go
    cammage08 likes this.
  7. aviel131
    aviel131 Member
    104
  8. Mi11ar
    316
    35
    I'm abit of a noob to all this can you send me a link to the part I need? lol
  9. Mi11ar
    316
    35
  10. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    538
    Yes although it's not totally advisable in the long run as the other 3 are still tired so it would be best to change all 4 at the same time.
    2 coil packs from TPS were the same as a full set of TFSI one's from Awesome GTi at the time I replaced mine + the adapters (plastic from TPS) = a no brainer
  11. Mi11ar
    316
    35
    if buying the 1 fixes the issue I'll then buy all 4 but going for the cheap options to wittle down the possibilities
  12. Mi11ar
    316
    35
    Ordered the part it will be ready for 3 o'clock today I'll get back to you :)
  13. Mi11ar
    316
    35
    Do the coils just unclip from there wiring btw?
  14. aviel131
    aviel131 Member
    104
    yes push them up with flat screw driver and pull back.
  15. Mi11ar
    316
    35
    Thanks hopefully this bloody solves my issue!!! lol
  16. kwistof
    2,434
    538
    Yes but be very gentle....3 out of my 4 clips are broken and extremely brittle.
  17. Mi11ar
    316
    35
    ok thanks :)
    Another thing a Red Service lights come on my dash, it was cleared at a garage because the Cars been recently serviced (when I got the new engine fitted) but almost straight away it came back on, could this have anything to do with my issues?
  18. s3joe
    s3joe Active Member
    588
    92
    Try swapping the coil packs round first and see if the missfire follows the pack
  19. Mi11ar
    316
    35
    oh yea good idea
  20. Mi11ar
    316
    35
    YYYEEESSSSSSSS!!!!!!!!!!!
    The problem is following the coil pack! and the clean spark plug is now also sutty!! meaning it must be the pack!! so ****ing happy right now haha, hopefully the pack does fix it otherwise I'm going to look a right ****'ed now haha
    Thanks lads!!
  21. cammage08
    cammage08 Member
    171
    10
    Ahem^^^
    Mi11ar likes this.
  22. bree9482
    bree9482 Member
    206
    13
    Hope it sorts it for you dude ;)
    Mi11ar likes this.
  23. Nilz
    Nilz Defo worth the wait :) Team Ibis TFSI Owners Group quattro Audi A4 saloon S-line owners group Manual
    11,367
    908
    Keep us posted and a quick note, when you replace it, go for a genuine one, if you go TPS or Dealers, they come with a 2 year warranty.
    Mi11ar likes this.
  24. Mi11ar
    316
    35
    Will do walking over the garage for the pack now! :)
  25. s3joe
    s3joe Active Member
    588
    92
    Glad it sounds like it is sorted
  26. Nilz
    11,367
    908
    Its crazy how many issues these bl00dy coilpacks cause!!!
  27. Mi11ar
    316
    35
    ok the Cars sorted!! :)
    Thanks a million people you have all been great! the mechanic I was using was at a loss and wanted me to spend £200 on a remap, so I'm very happy! :)
    1 thing though the Car starts funny and the rev counter bounces to near staling point, so on payday I'm going to give the Car a good self service and replace all of the packs as I can imagine the others are on there way out also.
    Spatula and kwistof like this.
  28. kwistof
    2,434
    538
    Got to love a happy ending :beerchug:
    ps don't go back to that mechanic again lol
    Mi11ar likes this.
  29. Spatula
    Spatula A4 B6
    272
    26
    Glad you're sorted! :)
  30. Mi11ar
    316
    35
    Any idea what the idle problem is all about?
    This video is what I made before the Car ****ed up completely and it basically shows the problem that hasn't went away (although the Car is fixed) is it just the fact that the other 3 packs need replacing?
  31. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Check your battery is fully charged as mine was a bit funny starting from cold as it looks like it was too low to provide enough amps
  32. s3joe
    s3joe Active Member
    588
    92
    Ring Audi to see if your car is on a recall list for coil packs
    Nilz likes this.
  33. Mi11ar
    316
    35
  34. Nilz
    11,367
    908
  35. rustynlc
    rustynlc Member
    186
    20
    back to basics my friends, see if you can get someone to carry out live data no fault codes suggests that the sensors are working, coil packs can start to fail and not flag up a code even on vagcom (happened to me) check fuel delivery, check air delivery and check ignition, sooty plugs are normally due to running rich, over fueling or faulty ignition,
  36. rustynlc
    rustynlc Member
    186
    20
    delayed post! i only seen page 1! :wtf: glad you got it sorted
  37. Broken Byzan
    13,237
    466
    no recall on AGU packs.
  38. Mi11ar
    316
    35
    That's a shame they're only cheep anyway, like I said the Cars sorted but I can just feel that there's something not right especially with the revs bouncing all over the place, so I'll replace the last 3 packs and see were that takes me.
    What are your opinions on this?
    ECS Tuning - 1.8T to 2.0T Coil Pack Conversion Kit - A3 (8L) - Audi - Shop By Car | Awesome GTI
    Thinking of getting this aswell since my new sump (cracked my old one) didn't come with the hole for the oil level sensor
    ECS/Genuine Tuning Coilpack Wiring Loom Replacement for cars Without Oil Level Sensor - Tuning - Engine - Parts | Awesome GTI
