Cars got even worse!!! (with videos)
Mi11ar Feb 13, 2014
  1. Mi11ar
    Mi11ar Active Member
    316
    35
    Hi guys
    Been posting a few times about problems with my Car and I've been given loads of advice by people and I've tried it all and still my Car isn't sorted, problem is the Cars running like a bag of ****, I replaced the engine because my last one seized, along with that I had a de-cat, Honda S2000 air filter and a universal FMIC fitted, since then the Cars just ran terrible, at first it was ok and then it progressed on only happening after an hour or 2 of driving, we plugged it into diagnostics and nothing is coming up everything's running perfectly fine or atleast the system thinks it is... So we replaced the spark plugs and that actually solved the problem for a couple of weeks then it came back and eventually the problems just got progressively worse.
    We've swapped parts over from the old engine to try an fault find basically all the sensors have been swapped about apart from the MAF as that's showing up fine on the system.
    I recently bought new sparks in a hope it was just them again and nothing changed as expected.
    Anyway made these videos and took some pics to try and help.
    99 Plate Audi A3 problems - YouTube
    99 plate Audi A3 exhaust problems - YouTube
    New sparks
    Removed old spark
    New spark after being in engine 3 minutes
    All the sparks were all covered in black ****ty dust, and the 4th plug wouldn't screw in properly when I was tightening it it felt like it was cross threading or something was in the way, I attempted it 4 or 5 times but each time went in strange, the plug was straight and tightened up as normal it was just the process of screwing it in that felt odd.
    Anyway I'm at a complete loss the mechanic I always use says it needs a remap and the ECU needs taking out for it, he's pretty dead cert on it being that actually.
    What are your thoughts?
  2. s3joe
    s3joe Active Member
    560
    78
    What year and engine code
  3. Mi11ar
    316
    35
    1999 and AGU I think
  4. Mi11ar
    316
    35
    I tried running the Car on 2 cylinders and it worked so I went through them always leaving at-least 2 plugged in and I've narrowed it down to the 2nd cylinder as only when that lead and any of the other 3 are plugged in does the the Car not run.
    Not only that all 3 other plugs are filthy apart from cylinder 2s plug...
  5. cammage08
    cammage08 Member
    171
    10
    Have a swapped coil packs over?
  6. Mi11ar
    316
    35
    Not sure what you mean, have I bought a new coil pack? or have I got the leads mixed up?
  7. cammage08
    cammage08 Member
    171
    10
    Sorry yeh, have you tried replacing the coil packs?
  8. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Tried the ignition amplifier on the airbox? deff only running on 3
    Mi11ar and cammage08 like this.
  9. Spatula
    Spatula S3 8P
    257
    25
    ^^^ what did you do with your ignition amplifier when you removed your old air filter box and replaced with a cone?
  10. Oranoco
    Oranoco Well-Known Member
    3,799
    349
    This would be where I would be looking :)
    Mi11ar likes this.
  11. Mi11ar
    316
    35
    Yes it could be that actually! I tied it to some trunken near were the old air box was, but the mechanic that changed my engine has left it hanging in the engine compartment it could have been knocked or had moisture on it causing it to fail.
    This will be why he thought it needed a map because that will have helped control the air/fuel mix, I'll get onto finding myself one asap Euro Parts sell them? and how difficult are they to replace?
  12. s3joe
    s3joe Active Member
    560
    78
    Yer Euro sell them all they do is plug in like a coil pack
    Mi11ar likes this.
  13. Mi11ar
    316
    35
    Can someone send me the link for them on Euro Parts or somewhere similar that does next day or weekend delivery? I can't seem to find them :s
  14. drewman
    drewman Member
    43
    I had a problem with the wiring from ignition amp (i think) to coil pack, cable had almost broken making a poor connection and intermittent stutter.
    Might be worth a check
    Mi11ar likes this.
  15. s3joe
    s3joe Active Member
    560
    78
  16. Mi11ar
    316
    35
    Thanks allot guys I've ordered it and will arrive Saturday I think I'll keep you all posted!! :)
    JudderMan and cammage08 like this.
  17. Spatula
    Spatula S3 8P
    257
    25
    Good luck buddy! Hope that's fixed your problem!!
    Mi11ar likes this.
  18. Mi11ar
    316
    35
  19. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Ignition amplifier? Never heard of this. Is this present on 2002 vehicles?
  20. Spatula
    Spatula S3 8P
    257
    25
    It's the little sensor thing attached to the side of the box air filter, has a cable coming out of either side and when unbolted has a metal heatsink strip thing across the back. More than likely present on the 2002 vehicles..
  21. JD09
    3,096
    46
    Interesting. I have nothing attached to my airbox as it's been sat in my shed for two years since fitting a larger TIP... worrying! Lol.
  22. Gops
    3,193
    663
    Not on ours JD! We don't have it. Out coilpacks are different and don't have an ICU
    Spatula likes this.
  23. JD09
    3,096
    46
    Cheers Gops!!
  24. s3joe
    s3joe Active Member
    560
    78
    It's only on agu engine codes a normal garage won't know it's there and say it's a ecu fault I got a golf turbo with loads of mods on it a few years ago by a garage saying it requires a ecu and it was this cost me £100 job done
  25. Mi11ar
    316
    35
    Yea that's exactly what my garage was saying they were asking for £200 for a custom map which wouldn't have solved the issue.... lol
  26. s3joe
    s3joe Active Member
    560
    78
    No not one bit waste of £200
  27. Mi11ar
    316
    35
    Might sound like a stupid question but - the part doesn't arrive until Monday but I'm in work Monday and will need my car to travel there, will driving the Car in this state risk damaging it more.
    I think I know the answer to this already I'm just hoping for a miracle.
  28. s3joe
    s3joe Active Member
    560
    78
    yep very much so did you shop about for it as i got one the same day
  29. Mi11ar
    316
    35
    used the link you gave me and paid extra for next day delivery on Thursday... only for it to arrive Monday lol
  30. s3joe
    s3joe Active Member
    560
    78
    fair enough i got mine from culmac
  31. Mi11ar
    316
    35
    I've emailed them anyway if push comes to shove I'll get the poverty bus to work 8 miles away haha
  32. RobinJI
    RobinJI Active Member
    176
    26
    Hopefully the ignition amp will sort it, but if it doesn't:
    Have the injectors been checked? If one's clogged/jammed then the other 3 will be chucking extra fuel in to keep the lambda sensor happy. It'd explain why 3 plugs are sooting up and one's staying clean. You could try moving the injector and coil-pack from the cylinder you know isn't firing to 2 different cylinders, and see if the miss-fire moves with either component. (Simple, free and rules out 2 more possibilities.)
    It could also be worth checking it hasn't got a 4 bar fuel reg or bigger injectors in there too, as either could cause over-fueling and would be easily missed when fitting a replacement engine.
    Good luck with it.
    Mi11ar likes this.
  33. Mi11ar
    316
    35
    Thanks I'll try this out if the amp fails me :)
  34. Mi11ar
    316
    35
    ok fitted the ignition amp and nothings changed, do I need to disconnect the battery or do anything after fitting it or should it just plug and play?
    if it's not that is there any other quick checks/fixes I could try?
  35. s3joe
    s3joe Active Member
    560
    78
    Its just a plug and play. Your wire harness has not been damaged when you done your engine change
  36. Mi11ar
    316
    35
    The wiring loom that came with the engine was wrong apparently and the one on my old engine didn't fit so he had to make his own using the 2 it is possible that he's got this wrong but if that's the case it doesn't help me as there's not much I can do about that now.
    I needed to get to work today in the Car but took a day off thinking this part would solve my issues I need to get to work tomorrow and it's still not fixed.... is it possible the Car may have not yet picked up the change or? I'm at a complete loss, the leads have been changed, the crank shaft sensor (or w/e it's called) has been changed, spark plugs changed twice (that fixed it once before)
    Only thing I can think of is a faulty lambda as he tried to remove the sensor from the de-cat pipe but it wouldn't budge as it seems to have now seized into place and he can't remove it without risking damaging the sensor.
    Thoughts?
  37. cammage08
    cammage08 Member
    171
    10
    Did u say youd replaced coil packs with new ones?
  38. aviel131
    aviel131 Member
    104
    tryed the coil packs?
  39. Mi11ar
    316
    35
    I used the ones from the old engine a while ago and that never solved the problem, although a few moments after doing that I changed the spark plugs which did temporally solve the issue.
    How do I test the coil packs again?
  40. aviel131
    aviel131 Member
    104
    maybe the gap of the spark plug is incorrect
    or your problem is cylinder compression.
