Cars been off for days still showing 90 degrees
Eddie S3 Sep 3, 2013
  1. Eddie S3
    Eddie S3 Member
    128
    9
    Last thursday took the car out and got an engine coolant tempature warning (was at 110degrees)
    Left it over the weekend thinking it was the broken plastic bits on the waterpump, but today when I turned the ignition on the temperature gauge is still showing 90degrees?
    Is it more likely to be the sender, thermostat or will a broken pump have caused both to fail
    Hopefully someone can shed some light on it, Thanks
  2. <tuffty/>
    21,875
    4,202
    If the engine is cold and the temp gauge is showing 90deg then its likely to be the CTS...
  3. Eddie S3
    Eddie S3 Member
    128
    9
    Cheers ill give it a go and hopefully that'll be it sorted :)
  4. amicallef1991
    amicallef1991 Member
    61
    Any luck with this?
    Thanks AJM
  5. Tim_Attard
    Tim_Attard Active Member
    473
    44
    Chante the sensor first as its so easy and cheap, then thermo but i hated doing it as its a pig
  6. amicallef1991
    61
    Nice one will do,
    Thanks AJM
  7. amicallef1991
    61
