Car wont start
Wilts Jun 11, 2012
  1. Wilts
    Wilts Member
    100
    Hello guys when i go to start car i turn it over and it starts then goes of after a second or so, it does this 4-5 times then starts could it be fuel pump if so how hard or expensive is it? Many thanks!!
  2. <tuffty/>
    21,805
    4,173
    Sounds like immobiliser kicking in... does a key shaped light flash up on the dash?
  3. Wilts
    Wilts Member
    100
    Il av a look mate
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Crank Sensor,
    Fuel pump, or fuel pump relay,
    immobilizer
  5. Wilts
    Wilts Member
    100
    If just tried it 3 times in 30mins and starting fine now but will have to check above
  6. <tuffty/>
    21,805
    4,173
    Could be that the battery just needs changing on the key... a scan with VCDS would show an engine start blocked by immobiliser fault code typically if the immo was kicking in
  7. sideways steve
    sideways steve Member
    347
    Tufty, changing the battery on the key wont affect the immobiliser as the chip in the key relating to the immo doesnt use any battery power, it is energised by the ring in the steering column.
    The battery in the key is purely for the remote function for the central locking. :)
  8. Wilts
    Wilts Member
    100
    How can i get a code reader or does any1 around torbay area hook my car up pleeeease!!
  9. Dalton
    Dalton New Member
    The most common cause is going to be your battery!
    ____________________________
    renault can clip v119 at Allobd2.com
  10. sideways steve
    347
    Ill say again folks ..... the battery in the key does not have anything to do with your immobiliser ! you could remove it comepletely and the car will still start off the key ! All the battery is for is the remote central locking.
  11. vagtronics
    vagtronics New Member
    hi did you sort it mate? it does sound like your immobiliser could be at fault.
