Car wont start? Warning light wont go out!
chale989 Mar 12, 2013
  1. chale989
    chale989 Member
    79
    My glow plug warning light will not go out!
    Its in a solid state and has been taking up to 10 minutes to go out previously.
    I have replaced all 4 glow plugs and the battery.
    When the car is warm then it will go off instantly
    Would replacing the control plug relay be next?
  2. hades-
    9,482
    646
    have you had it scanned for faults yet ?
  3. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    When were the GPs and batt changed?
  4. chale989
    chale989 Member
    79
    I have had it scanned 3 times now.
    They indicate back to glow plug failure but the glow plugs changed around 2 months ago and battery 1 month ago. Brand new parts of course.
    Audi cleared the error which made it work fine for a day or two and then it gets increasingly worse.
    I sometimes sit in the car for 10-15 minutes before the light will click off itself.
  5. NHN
    29,593
    1,782
    The glowplug/injector loom are known to fault, swap this & retest, then look at other options.
  6. chale989
    chale989 Member
    79
    Is this a big job?
    Something i can get second hand?
    I called audi but they wouldnt give me any part number for anything.
    their words were "if we arent making money on it then we cant give out the information"
    Edit : is this what you mean
    Audi injector and glow plug wiring loom 03G971033M A3 2004 2008, A4 2005 08 | eBay
  7. NHN
    29,593
    1,782
    Buy new from audi, 2nd hand guarantees nothing.
    I'm not saying its this, but its logical thing to look at.
    Yes I agree with audi, they are there to earn money & sell parts at the end of the day, they have to pay salaries for these guys & we don't pay them for information, so I think they're justified in there stance.
    Rocker cover of.
  8. chale989
    chale989 Member
    79
    That part isnt second hand that i sent the link to.
    Audi would probably charge double that for the above part
  9. NHN
    29,593
    1,782
    Regardless, considering the importance of the part, I would buy new from audi, do as you see fit.
  10. hades-
    9,482
    646
    id also buy new from audi or TPS
    otherwise you never kow what your geting
  11. max69vk
    max69vk Active Member
    862
    57
    Give Audi UK a call & give them your Car reg to see if the injector recall has been done, if it hasn't, under the circumstances they may pick the car up on a trailer & do the injectors & loom FOC - 0800 699 999
  12. chale989
    chale989 Member
    79
    No know recalls for my engine apparently.
    i do have a full print out from audi diagnostics.
    01049 012
    vehicle voltage terminal 50
    electrical malfunction in circuit
    static
    00955 005
    key 1
    no or incorrect basic setting/adaption
    intermittent
    17055 p0671 000
    cylinder 1 glow plug circuit
    static
    if anyone can help me with any of those faults it would be great
  13. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    606
    34
    what glow plugs did you use when you replaced them? A good brand? eBay specials?
  14. chale989
    chale989 Member
    79
    I used Bosch ones. Which were reccomended by audi.
    There are no known faults/recalls with my engine audi UK have said.
