Car wont start - anyone to scan ASAP? (Manchester, M40)
wrightyrx7 Nov 19, 2013
  1. wrightyrx7
    wrightyrx7 Member
    117
    Hi there,
    Car wont start again!! Second time car car has frozen this year. Second time the dash gets no power.
    Last time by the time i had finished work and got home it started fine. Which makes me 99% sure its the weather causing this problem.
    I am aware that the fault need to be there for its to be picked up. What i dont want is later the car the defrost and the error go away.
    Is anyone available to come to me Manchester, M40.
    Will pay of course.
  2. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Gold Supporter quattro Audi S3 s tronic
    25,408
    8,490
    wrightyrx7 likes this.
  3. wrightyrx7
    wrightyrx7 Member
    117
    Cheers Sandra, I have spoke with N8 before, but my car wont start until defrosted :O (i hope)
    My worry is that there will be no fault when the car is up and running (when defrosted)
  4. Sandra
    25,408
    8,490
    Click on his Kowalski link and you will get his mobile number, maybe he will come to you. :) x
  5. wrightyrx7
    wrightyrx7 Member
    117
    Hi Sandra,
    Spoke with N8 he is going to scan it if he gets time this afternoon. You know of anyone else i can try as back-up because I only have today free because i couldnt get to work this morning.
    The car is starting now its defrosted :/ apparently the errors are recorded so will be able to find out what the problem was. Apparntly
  6. Sandra
    25,408
    8,490
    Give me a few minutes and i will check. :) x
  7. Sandra
    25,408
    8,490
  8. wrightyrx7
    wrightyrx7 Member
    117
    Many many thanks Sandra :)
  9. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,794
    190
    Im in bolton EARLY on friday. if you have this problem still come friday pm your number and ill pop round. ill be limited on time though.
  10. wrightyrx7
    wrightyrx7 Member
    117
    Hi all,
    Aidy06 kindly scanned my car. Thanks for all your help.
    Still didnt find out the issue :(
    I have made a video, incase it helps shed light on my problem.
  11. Aidy06
    Aidy06 Member VCDS Map User
    412
    19
    Has it happened again Chris? Could try and scan it again and see what it finds? I cleared all faults the other day so whatever shows up now if anything will be related
  12. wrightyrx7
    wrightyrx7 Member
    117
    Hi Aidy,
    No I forgot I had recorded this video the other day (as back-up, because I'm sure my boss thinks I was lying to get a day off work haha)
    So its not happened again *yet* but waiting on the next frosty night.
  13. @udi A3
    1,794
    190
    Cluster fault. Do you want me to help you out in the morning?
    I can swap a set of clocks into your car to confirm or prove myself wrong!! :D
  14. Aidy06
    412
    19
    You think it's definitely cluster fault Tom?
  15. @udi A3
    1,794
    190
    Im 99% certain. I have spare clocks and tools to swap them, and to temporarily disable the immo. One way or the other i would be able to conclusively confirm or rule it out.
    Were there any errors on the original log relating to key low signal or internal ecu errors?
  16. wrightyrx7
    wrightyrx7 Member
    117
    There were no errors except one with the alarm. Aidy said its something to do with the horn not sounding when the alarm is going off. Which i can confirm, when the alarm goes off it beeps and the horn doesnt sound.
  17. Aidy06
    412
    19
    No mate, nothing of the kind. Just a backup horn fault, which as Chris said above is to do with the alarm
  18. Aidy06
    412
    19
    You'll have to let me know if it happens again mate and if I'm about I'll get over to you and try and find the cause
  19. wrightyrx7
    wrightyrx7 Member
    117
    I will do mate, but both times its happened has been on a weekday. Next time it happens you will probably be on your way to work while im ripping my hair out in my garden :uhm:
