car wont start after turning it off
Ballcrusher Sep 27, 2007
  1. Ballcrusher
    Ballcrusher NO CAT JUST 3" STRAIT THREW
    347
    as above started last week only happens every now and then but when i turn the car off then try to start it again it turns over fine but wont start every thing seems fine apart from starting......?
  2. TheSpaceCowboy
    TheSpaceCowboy Member
    520
    Could be the fuel pump, I'm not sure if they are on a seperate fuse but find out which fuse its on and replace it, I could find out a bit later with the proper literature, if not you may need a new fuel pump. Check to see if the immobilisor light comes on too mine does this every now and again and audi want £110 p/h just to diagnose it!
  3. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Can't be a fuse if it's intermittant, immobiliser is more likely, but the engine would then start & die, rather than not start at all.
  4. TheSpaceCowboy
    520
    Ah didnt read it properly, my dads motor did do it intermittantly but that was a fuel pump problem, the fuse blew eventually after starting/not starting, then we replaced it and it worked for a couple of days then wouldnt start at all, didnt blow the fuse either eventually changed the fuel pump and it works.
  5. steebo888
    steebo888 Member
    218
    also fuel filter £4.50 ish from vwspares
  6. Aky
    Aky Aky
    1,512
    I'd put my money on fuel pump - no fuel, no start
  7. IN-A3
    IN-A3 Member
    457
    Try crankshaft sensor
  8. Ballcrusher
    347
    ok guys some of you got close but all it turned out to be faulty fuel pump relay behinde fuse box changed it all sorted now cheers all for your replys. :applaus:
  9. TheSpaceCowboy
    520
    Glad its sorted mate
  10. Ballcrusher
    347
    sorry to say guys the problems still here it seems that the relay only works every now and then. i put a new one in and nothing then al of a suddon it starts working again wat would stop the relay from working
  11. TheSpaceCowboy
    520
    Im gonna just say the fuel pump because its the exact same thing that happened to my dads car and eventually it just wouldnt start, give it a couple of weeks and see what happens, if it stops working all together id go with the fuel pump.
  12. Ballcrusher
    347
    ok guys it turned out to be crank sensor cheers every one
  13. jbw
    jbw Member
    194
    Crank sensor huh? I've had this since the day I bought my 1.6 a3. Audi have never picked up on it via the computer read out.
    Ballcrusher can I ask how much this set you back?
    ta,
    jbw
  14. AwesomeSarah
    AwesomeSarah Member
    726
    Hi
    I know that the coolant temp sensor can cause problems on short journeys
    The sensor reads incorrectly and can read it being warm or cold engine so can under or over fuel when engine is slightly warm
    These are VERY common and they have a superceeded part
    The green ones are the new ones and superceed the black ones
    So if you have black , it could be worth replacing them
    Other than that good luck guys
    Sarah
  15. Ballcrusher
    347
    at first the snapon diagnostic picked up a rpm sensor witch turned out to be the crank case sensor changed it all sorted
  16. IN-A3
    IN-A3 Member
    457
    Sorry guys been there before!
