car wont rev past 1500rpm
rydinator Mar 15, 2011
  1. rydinator
    rydinator Member
    72
    as the title states, my car will turn over and tick over but it wont rev past 1500rpm, i have tried everything pretty much:
    fuel pump
    cleaned the injectors
    replaced the throttle body and maf sensor
    and not long ago i changed the engine temperature sensor and lambda sensor
    It seems to be intermittent as it was running on sunday although it wasnt boosting and then a loss of power and the revving problem
    So what else could it be causing this?
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    You need to get it on the computer mate, unless you will be spending on parts forever
  3. rydinator
    rydinator Member
    72
    already have mate, didnt come up with anything apart from
    17967 - Throttle Valve Control part (J338): Fault in basic settings
    P1559 - 35-00 - -
    17973 - Throttle Actuator (J338): Lower Stop not Reached
    P1565 - 35-00 - -
    ive done everything it says to do on the ross tech website and still nothing, its doing my head in now!
    it also wont let me do a TBA, and when i turn the ignition on i cant hear anything from the throttle body, although it was running and driving on sunday and then it done it again.
  4. s3dave
    10,110
    736
    Ah yes i remember now did you check the throttle body wiring? and where was the new TB sourced?
  5. rydinator
    rydinator Member
    72
    oh yea i remember you commenting last time lol, its just doing my head in, i dont want to keep bringing it up, but i just want it sorted. Yea i checked the wire it all seemed fine and it was a second hand one sourced off ebay, but i was assured it was fine. Do you think it could still be the throttle body though even though it has been revving past 1500rpm?
  6. s3dave
    10,110
    736
    Who knows ebay parts could be good or bad its a lottery, did you get a battery?
  7. rydinator
    rydinator Member
    72
    yea got a battery and that didnt make any difference, i dont like taking my car to the garage for them to tell me something i already know, thats why i want to try sort it out myself, but its been about 4 weeks now and i think im gonna have no choice in a minute!
  8. s3dave
    10,110
    736
    Are the exact fault codes coming up on each throttle body? old one and ebay one? there might be some one on here who is selling one who have upgraded to the r32 TB
  9. rydinator
    rydinator Member
    72
    yea the exact codes were coming up on both of them. Its an agu, so its cable throttle. Could it be a faulty ecu? Vaccum leak? bad earth?
  10. s3dave
    10,110
    736
    It wont be a vacuum leak bad earth maybe, trouble is you dont know for sure the ebay one is good?
  11. rydinator
    rydinator Member
    72
    thats the thing, i dont know if it was ok before i got it, the person i got it off said it was working fine when he removed it, only way i can find out is to try one i definately know is working, but then i might put the same error onto there one! how could i go about checking the earths?
  12. Pazz
    Pazz New Member
    Having the same problem, but only when cold - revs drop to 1100 and stay there.
    Throttle Body cleaned, nothing on VAGCOM, no vacuum leaks, MAF cleaned.
    You had any joy?
  13. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Have seen a similar problem which turned out to be the crank speed sensor. When it revs does the rev counter go bananas and bounce all over the place?
    No fault codes listed for this problem either, the CSS was a shot in the dark.
