car shaking
mooey Jun 26, 2010
  1. mooey
    mooey New Member
    I have got a 2006 A3, 170bhp 2.0 tdi. When it reaches around 50 it starts to shake, not a steering wheel shake more through the hole body. It carry's on till around 65-70 then disappears. If you drive straight through it it's not too bad, but if your'e sat doing say 55-60 mph its very bad. It's there no matter what gear the car is in.k Any help much appreciated. Mooey
  2. matt a
    matt a Member
    69
    Need to have your wheels balanced. :friends:
  3. mooey
    mooey New Member
    I Had that done its a lot worse than a wheel ballance issue mooey
  4. robby
    robby Active Member
    579
    69
    does it pull to left or right?
  5. mooey
    mooey New Member
    No its just the shaking
  6. GAudiTech
    GAudiTech Member
    does it do it when coasting at this speed or only under acceleration?
  7. mooey
    mooey New Member
    No when accelerating in ok its just when you are driving at a set speed ie in a line of trafic
  8. GAudiTech
    GAudiTech Member
    Quattro?
  9. philipjmarshall
    philipjmarshall Member
    91
    Mooey, could be several things wrong.
    1 - Did you balance all 4? as hi speed wobble always comes from rear wheels.
    2 - It could also be a tyre has bulged or gone out of shape, (common problem at my tyre centre with all the potholes about)
    3 - have you had them (dynamic balanced? weights mounted on 2 planes from rear of wheel and behind spokes and back edge_ this is the most accurate method), or (static balance - one set of weights mounted just on inside back edge only - no were near as accurate, but used my many tyre centres as it easer, quicker and uses less weight)
    hope this helps, let me know.
    philip
  10. mooey
    mooey New Member
    Ive just had thought from you said about tyers the car done 102,000 and is making a humming nose wich i thought was a wheel bearing jacked it up no play enywhere maybe its linked mooey
  11. GAudiTech
    GAudiTech Member
    is it quattro??
  12. philipjmarshall
    91
    yes it sound like its defiantly a rear tyre problem, its ether worn on the inside edge down to canvas and has delaminated. or its worn "steppy of corrugated " on the rear inside edges, the noise sounds like wheel bearing has gone when it hasn't. you find this a lot with front wheel drive cars also most common if drecional tyres fitted.
    Philip
  13. mooey
    mooey New Member
    No its not a quattro ,and can i spot if its got a tye problem by looking mooey
  14. philipjmarshall
    91
    try swooping fronts to rear see if speed of wobble changes.
  15. robby
    robby Active Member
    579
    69
    best thing to do is remove the rear wheels and see if there's any visable damage, if nothing is visable then try swapping tyres front - back
  16. PH1L
    PH1L Gievf Buckets
    3,851
    40
    it deffinately sounds like misbalancing of the wheels, bad tyres or a warped alloy, possibly i steering rack though i doubt that one
  17. shilts
    shilts Member
    222
    Had exactly the same problem ! I needed four new tyres anyway , and when i changed them the problem went away .
  18. dantdi
    dantdi ...
    521
    Hate to say this but mate had this on his golf. it was the drive shaft.
  19. matt a
    matt a Member
    69
    Have a look at all your tyres, as I had a similar issue on my Caddy van, it turned out to be one of the rears tyres was worn bare in one part.
  20. mooey
    mooey New Member
    Well thanx lads i will try the tyers and let you mooey ps breaking a mk1 golf soon if anyone needs bits
  21. pi quattro
    pi quattro Member
    127
    I had someting similar in a van i had once. Took months to resolve. It was a slight bulge on the inside of a rear tyre. Was only spotted with tyre off the van.
    I couldn't see it when looking as the bulge was probably at the top. When it was at the bottom it looked normal as all tyres bulge at the bottom!
    You can only spot it with the tyres off. Probably a good thing to do in your case and then swap them round too.
