Car shakes/wobbles when stationery
Harrelson Dec 17, 2010
  1. Harrelson
    Harrelson Member
    173
    1yr old 1.6TDI, 9000miles. When warm and stationery, in neutral i can feel the car wobble and shake. Only happens occasionally but happened at almost all traffic stops today. My passenger even commented that it shakes like a car of the 50's!
    Used search and seen suggestions of dual mass flywheel, looms etc but that was on older 8L and the PDI engines.
    Not sure if whether to ring Audi, Bristol. Are they gonna charge me? Its x-mas time and i would hate that. Car is still under warranty. Help me!
    other details -'from DIS' oil change due in 10000miles and service 722days so well looked after and on schedule
  2. dickys3
    2,963
    23
    If its under warranty mate, just take it to Audi and see what they say.
  3. Harrelson
    Harrelson Member
    173
    Will ring them up, hope its not effing wear n tear
  4. Jonay
    Jonay Member
    274
    Can't imagine it'd be wear and tear.. what's to wear and tear when idle on a 9k car?!
    I place bets being on the flywheel.
  5. mike foster
    3,967
    Just give it back to the dealer and ask them to fix it. It won't cost you a bean !
    But before you let them have it make sure they have a courtesy vehicle available for your use until it gets fixed.
  6. heeman10
    heeman10 Audi driver since Dec 08
    375
    Does it make noise? Has to be an engine/gearbox mount or flywheel really!
  7. smudge_don
    smudge_don Active Member
    2,944
    Sounds like the old flywheel issue on the 2.0TDI's
    I had a fault on my 07 2.0TDI after just 23k miles, so it's not uncommon to have something wrong, even with a newish car
    Take it to Audi and have them get it done under warranty
  8. Harrelson
    Harrelson Member
    173
    Thanks for the suggestions. Gave them a ring and booked for a check in 10 days
  9. buftonian
    buftonian New Member
    Hey, did you manage to get this issue fixed? Let me know as my Allroad has the same problem. Cheers!
  10. Harrelson
    Harrelson Member
    173
    Went out for a test drive and it didn't occur. So asked to wait for it to happen again and they will do a check on the engine
    In my experience it keeps happening randomly but now almost always when the engine is warm and stopped in traffic facing uphill
  11. supanova
    supanova A3 2.0 TDI SE
    539
    22
    my car also does this ocassionally but I didn't really take any notice but ithink I'll maybe check it out.
  12. J8TT X
    J8TT X Member
    360
    9
    My A3 does the exact same, when its warm and idiling????
  13. Rigla
    Rigla S Line
    im part of this club also
  14. AudiMafia
    AudiMafia Member
    403
    13
    sometimes it happens to me when i iddle and if my foot/ is on the brake or if my hand brake,,, i rarely feel it if braking is not involved
  15. snack
    snack New Member
    did this get fixed at all? I've got a 1.6 04 A3 and having the same problem. unfortunately i dont have warrenty so could be expensive
  16. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    Got 04 2.0tdi and despite having the flywheel replaced nearly two years ago, the car has always had the vibration when idle and warm.
    Guess it might be the loom in my case.
  17. Harrelson
    Harrelson Member
    173
    mine comes and goes. more apparent in hot weather but i never got it looked at. mentioned it to my dealer when it was going for a wheel bearing problem a while back and he gave me that look of "are you a f****** perfectionist, deal with it" so unless it becomes a major issue, ill live with it
