Car not starting, please shed some light!
Leeseager Nov 18, 2013
  1. Leeseager
    Leeseager Member
    41
    ​Car will run completely fine until it gets to engine temperature.. When it does it doesn't start again if you turn it off and on. I've had the cam sensor and coolant temperature sensor done as i was advised to but nothing has changed. (Car also is a little shaky on idle?)
  2. Leeseager
    Leeseager Member
    41
    Car is audi a3 2.0 fsi 2004
  3. Marshy
    Marshy Settled in Audi RS3
    1,352
    470
    Crank shaft position sensor would be my bet.
    Famous symptoms if them failing is they won't start when hot but will usually start if left 1/2 an hour.
  4. Leeseager
    Leeseager Member
    41
    have you had this? Wouldn't the crank sensor come up when diagnostic tested? The cam sensors keeps coming up on diagnostic and has been replaced twice
  5. Marshy
    1,352
    470
    The crank sensor when failing doesn't usually throw a code it gives a corrupt signal which usually condemns the cam sensor saying its signal is incorrect.
    Either that or your timing is wrong?
    Has it had a timing belt replaced recently?
  6. Leeseager
    Leeseager Member
    41
    oh so that would explain why the cam sensor keeps coming up. The guy i bought the car off said he had it replaced but he'd lost the receipt.. Just hoping it's not an ECU problem which'll cost a lot. The car is at an audi specialist now so they should be able to tell me whats wrong pretty promptly i guess.
  7. a3-205gti
    a3-205gti Member
    42
    Did you manage to fix the problem leeseager only my 2.0 fsi showing same symptoms any help would be much appreciated. Thanks
  8. a3-205gti
    a3-205gti Member
    42
    Sorry forgot to say ive changed engine temp sensor and engine speed sensor, changing the ess has much improved idling and general feel of the car but still tempremental on warm/ hot starting.
  9. Leeseager
    Leeseager Member
    41
    i haven't had any luck yet mate, sucks. Nobody on here seems to know what it is.
  10. a3-205gti
    a3-205gti Member
    42
    Nightmare, took mine to audi sheffield sheffield who wanted £800, was going to pay until they said they couldnt gaurantee it would fix it lol, that nhn guy seems to know his stuff and hes mentioned on other threads it could be battery or starter so there my next things to change, might have to wait till after christmas tho. Good luck
  11. Leeseager
    Leeseager Member
    41
    Best thing to do would be to switch parts with a car thats exactly the same.
  12. a3-205gti
    a3-205gti Member
    42
    No mate sheffield.
