Car mods dont always go to plan ;(
bluequattro Sep 26, 2009
  1. bluequattro
    bluequattro Member
    411
    Well after waiting all week to get the weekend off I thought yes ill crack on
    and fit my mfsw, having purchased a wiring loom for the inside of the wheel as well, i read as many posts as possible about coding and fitting etc, i removed the non mfsw and fitted the new mfsw along with new wiring loom to suit the wheel buttons etc, however the wheel remains functionless? the horn wont work either now? i coded it all in vagcom, i have no airbag errors either, below is a scan on vagcom if anyone can help
    aturday,26,September,2009,10:31:06:59303
    VAG-COM Version: Release 704.1
    Data version: 20071016
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 47 52 55 56 57 76
    77 7D
    VIN: WAUZZZ8P76A008244 Mileage: 43660km/27129miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    57-TV Tuner -- Status: Malfunction 1010
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: Cannot be reached 1100
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: None
    Part No SW: 03G 906 016 BA HW: 028 101 184 7
    Component: R4 2,0L EDC 0000SG 9882
    Coding: 0000172
    Shop #: WSC 66565
    No fault code found.
    Readiness: 0 0 0 1 1
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.LBL
    Part No SW: 1K0 907 379 R HW: 1K0 907 379 R
    Component: ESP 4MOTION MK60 0102
    Coding: 0023170
    Shop #: WSC 06314
    Address 08: Auto HVAC Labels: 8P0-820-043.LBL
    Part No SW: 8P0 820 043 J HW: 8P0 820 043 J
    Component: KlimavollautomatH15 0200
    Address 09: Cent. Elect. Labels: 8P0-907-279.LBL
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H36 1201
    Coding: A58A5F26A214100000000000000000000008FE175C0200
    Shop #: WSC 06314
    Part No: 8P2 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Address 15: Airbags Labels: 8P0-959-655-94.LBL
    Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
    Component: Airbag 9.41 H11 3520
    Coding: 0071612
    Shop #: WSC 06435
    Address 16: Steering wheel Labels: 1K0-953-549.LBL
    Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
    Component: Lenksäulenmodul 034 0070
    Coding: 0000012
    Shop #: WSC 06314
    Address 17: Instruments Labels: 8P0-920-xxx-17.LBL
    Part No SW: 8P0 920 981 BX HW: 8P0 920 981 BX
    Component: KOMBIINSTR. VDO H80 0460
    Coding: 0005413
    Shop #: WSC 00847
    Address 19: CAN Gateway Labels: 1K0-907-530.LBL
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Coding: FD0F0FDA070101
    Shop #: WSC 00847
    2 Faults Found:
    01303 - Telephone Transceiver (R36)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:40:12
    00467 - TV Tuner (R78)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 117
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:44:19
    Address 22: AWD Labels: 1K0-907-554.LBL
    Part No: 1K0 907 554 A
    Component: HALDEX 4Motion 0105
    Coding: 0000001
    Shop #: WSC 00000
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
    Address 37: Navigation Labels: None
    Part No SW: 4P0 035 192 Q HW: 4P0 035 192 Q
    Component: RNS-E HIGH EU H74 0650
    Coding: 0205715
    Shop #: WSC 61379
    4 Faults Found:
    00466 - Control Module for Steering Column Electronics (J527)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:36:55
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:37:01
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:48:29
    00850 - Control Output Active; Radio Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:37:00
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.LBL
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0050
    Coding: 0000632
    Shop #: WSC 06314
    Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
    Part No: 1K2 909 144 J
    Component: EPS_ZFLS Kl.3 D04 1606
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    000 - -
    Address 46: Central Conv. Labels: 8P0-959-433.LBL
    Part No: 8P0 959 433
    Component: KSG H03 0040
    Coding: 198000403F3F8D0D489AC63300
    Shop #: WSC 00853
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 B
    Component: Neigungssensor 004 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0020
    Address 47: Sound System Labels: 8Px-035-382.LBL
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH25 0160
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.LBL
    Part No: 8P0 959 802 H
    Coding: 0000632
    Shop #: WSC 06314
    Address 55: Xenon Range Labels: 8P0-907-357.LBL
    Part No: 8P0 907 357 C
    Component: Dynamische LWR H01 0010
    Coding: 0000002
    Shop #: WSC 06314
    Address 56: Radio Labels: None
    Coding: 0205715
    Shop #: WSC 61379
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:36:55
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:37:01
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:48:29
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 43668 km
    Time Indication: 0
    Date: 2009.09.25
    Time: 01:37:00
    Address 57: TV Tuner
    Cannot be reached
    Address 76: Park Assist Labels: 8P0-919-283.LBL
    Part No SW: 8P0 919 283 A HW: 8P0 919 283 A
    Component: Parkhilfe 4-Kan H09 0010
    Coding: 0000003
    Shop #: WSC 06314
    Address 77: Telephone
    Cannot be reached
    Address 7D: Aux. Heat Labels: 1K0-963-235.LBL
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    End --------------------------------------------------------------------------------------------------
  2. mattandrew
    mattandrew Member VCDS Map User
    977
    21
    You have a few issues here mate
    1. The steering wheel ECU is the wrong one you have 1K0 953 549 AF you need 8P0 953 549 F
    2. You may have an incorrect slip ring you need to check the part number on it
    3. You have a steering angle error which is related to the steering wheel ECU
    4. The navigation Control Module is Incorrectly Coded
  3. V6Pete
    V6Pete Now running on Bentley's y'all
    1,491
    Ok all that stuff means nothing to me! But I know on my 04 A3 I needed to change the slip ring and steering wheel ECU when upgrading to my FBMFSW.
  4. jameo84
    jameo84 Member
    122
    Hey Bluequattro whats the chance of you having a nice leather wheel on before that your looking for a new home for.
  5. bluequattro
    bluequattro Member
    411
    Hi m8, are you meaning you want to buy my non mfsw from me?
    Cal
  6. jameo84
    jameo84 Member
    122
    yeah
  7. jameo84
    jameo84 Member
    122
    after reading that back i was not very clear.
  8. jameo84
    jameo84 Member
    122
    Did you keep the same airbag when you changed to the mfsw, cos its the old style one i have on my 05 tdi, so think ill need to find one with the airbag included
  9. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,276
    165
    These are the same problems i had last week and i was using the new/ correct slip ring and controller. I eventually got rid of most of the fault codes by coding the RNSE again but i couldn't get the steering assist to work. Eventually i took it to Audi's and it took them 2 hours and £300 to get the steering wheel to recognise the RNSE and to get the car to recognise the wheel controller. something to do with the Can gateway ....That coupled with £100 for the slipring/controller, £450 for the wheel £240 for vagcom and £350 for a laptop etc makes a very expensive volume control :lmfao: we live and learn :yes:
  10. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    112
    paddy,
    i wish id of known mate, im gutted!!!
    ive got a laptop for sale! LOL LOL
