Car just cut out and won't restart! Please help!
Abb Jan 24, 2013
  1. Abb
    Abb Member
    309
    Borrowed an A3 sport back 1.9tdi 2007 model from a family member, started it fine this morning and then whilst stationary in traffic, the car without any warning, just cut out! Tried re starting and absolutely nothing, it was if an immobiliser had kicked in. Pushed it aside, and awaited recovery. AA man after several head scratches and said he hadn't come across anything like it, as the dash lights came on as norm, battery tested ok, fuses in tact. He then went to the starter motor and found that there was no power there at all. Stripping back a little of the outer insulation, he bridged the cable to a direct live, whilst the ignition was on and it started straight away, thus proving starter motor to be ok. Turned engine off and won't start again.
    Anyone heard of this or had this problem? Possible relay or a hidden fuse?
  2. NHN
    29,298
    1,701
    There's a relay in fusebox under bonnet iirc, but I would also check the cables leading to, for any bad conductivity on terminals, as this can occur over time.
  3. RobinA3
    RobinA3 Well-Known Member
    1,826
    45
    Sounds odd as it was running and then cut out - if the problem was that it wouldn't start then I would suggest it could be ignition barrel problem or something similar.
    Did the AA man check for fault codes?
