car judders a bit on cold start up and then is fine once up to temp
drfeelgood Jul 14, 2010
  1. drfeelgood
    drfeelgood Member
    225
    Hey guys, searched the fourms but cant find anything similar, other then anouther guy who said his car judders during all low rev range, the answer to that was the MAF?
    But anyway, on a cold start up the car seems to judder /hesitate a bit threw the entire rev range and into the high gears, however after a minute or so its fine. I'am thinking it might be this MAF sensor or maybe the brakes are locking up slightly and causeing it to judder and releasing a bit after driving , but the weather has been hot and there is no moisture in the air so i cant think it can be that.
  2. GAudiTech
    GAudiTech Member
    coolant temp sensor is likely cause of this. If its reading incorrectly and thinks the engine is warm when it is actually cold this will stop the fast idle causing the judder.
  3. drfeelgood
    drfeelgood Member
    225
    The temp gauge on the dash seems to read correct though, or wouldent this matter?
  4. GAudiTech
    GAudiTech Member
    check the sensor and see if its black or green. Change it if it is black. The temp gauge does not give a true temp reading. Only way to properly check would be to have a look at the measured value block using VCDS to see what its reading. There was a point in my work were i was fitting at least one of these a day to 8L with the exact same problem. Its somewere to start and is the cheapest option
  5. Dazboss
    Dazboss Like A Thristy Dingo ;)
    366
    Sounds like my problem too :(
  6. Sandip
    2,456
    99
    Try primeing the fuel pump up a few times then start the car, seems to be working for me
  7. drfeelgood
    drfeelgood Member
    225
    Audi can deal with it, have warrenty will use it lol
  8. drfeelgood
    drfeelgood Member
    225
    Where do i find the coolant temp sensor on the car?
  9. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    My car was doing the same thing on start up until i read the other guys thread about it being the MAF. I checked my MAF readings when i got my liquid gauge and realised it was down. I bought a new MAF and the car has been fine since then.
    Have you tried unplugging the MAF and taking it for a wizz to see if it feels better? If it does feel better then it means you need a new one. I did the same thing and my car pulled alot better when i unplugged it!
  10. finesse
    finesse Active Member
    2,805
    lol this ain't 1952 sandi
  11. Sandip
    2,456
    99
    :laugh:
  12. drfeelgood
    drfeelgood Member
    225
    To be fair it could just be me, the feeling of judder and hesitation is so small, how do i remove the maf, is it on the how to quide? I took it to audi, they couldent find anything wrong on the cold start up, so it might just be me being a prat lol
  13. finesse
    2,805
    remove wiring connector
  14. drfeelgood
    drfeelgood Member
    225
    Oh i have dealt with such things before on the astra, i will give this a try, nice to have something in such an easy place to get to
