Car jerking when releasing accelerator anyone help ?
TDI140 Dec 19, 2013
  1. TDI140
    TDI140 Well-Known Member
    1,626
    174
    Cars drivjng fine pick up and power is fine but when i release accelerator it feels like ive dabbed the brakes on and it feels liek its dipping down on the front and slowing down and not just rolling along i can feel it significantly when release accelerator, someoen said it could be egr valve clogged up and not allowing air to pass through efficiently ?? Anyone had this issue ?
    also everyone with egr delete says that there cars drive much smoother so im thinking its the same thing ?
    any advice is appreciated thanks
  2. Phil-1
    Phil-1 Well-Known Member Regional Rep
    2,017
    664
    Have you checked that you don't have a sticking brake? This could be why the nose dips when you ease off
  3. TDI140
    1,626
    174
    Brakes are all fine having all pads and discs replaced in january for the snow and bad weather to be safe. Its not brakes they have been all checked seems like egr clocked or something along those lines
  4. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    885
    If it was the EGR you would feel it elsewhere in the rev range and would probably be a nightmare to drive. Is it sluggish when cold or jerky under acceleration under normal driving conitions?
  5. TDI140
    1,626
    174
    Only happens in gear was thinkig boost leak but boost gauge shows no psi drop under load, ive already replaced IMF so its not that, brakes seem fine and functioning, yeah bit sluggish when its cold but thats normal isnt it ? I dont put strain on engine unless its warmed up
