car is taking too long to warm up? This normal?
max9650 Dec 23, 2013
  1. max9650
    max9650 New Member
    21
    Hi all since ive had my 1.8T Quattro its taken a while to warm up and sometimes it will even cool itself down when crusing on the motorway etc,
    So I got a new thermostat changed by a friend and he said there was some evidence of it letting coolant though when cold but now its done, it still took approx 15 miles crusing around 30mph-40mph to get to the correct temp, is this normal?
    I don't think it is personally.. So whats next on the list of things to check ?
    Thanks all.
  2. Nilz
    11,329
    876
    That is quite a long time mate, mine is normally warmed upto 90 degrees in about 3-4 miles.
  3. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
    Same as Nilz here mate....takes around 4 miles for it to show 90 degrees which is incidental the distance it takes me to get to work :(
    Not 100% sure on what you should need to check....a fault code run on VCDS would be the first point of call though to steer you in the right direction
  4. epox
    epox Active Member
    772
    74
    Is the heater blowing hot? If it is change the CTS.
    Mark
  5. max9650
    max9650 New Member
    21
    yep it does get warm but not overly hot
  6. Mike B
    Mike B Well-Known Member
    1,101
    40
    Was it a genuine stat?Others are unreliable
  7. gabin
    gabin Member
    131
    12
    Amateur question, what is the CTS? :think:
  8. Lewis583
    956
    91
    Coolant temperature sensor. Genuine sensors are unreliable enough and aftermarket can be even worse.
  9. Ian2012
    Ian2012 Active Member
    473
    29
    Did the cts on our old A4 and that was warm within 2-3 miles
