Car goes limp over 8 psi
Maccabee33 Jan 15, 2012
  1. Maccabee33
    Maccabee33 New Member
    20
    Ok so no idea if this is right but my car at the moment only boosts to 5 psi. I'm sure from what I have seen on here thats wrong! I have fitted a MBC and it does as it should and I can get upto 10/15 psi. How ever when I do this as soon as the boost reaches anythink over 8 it goes limp and feels like some giant is pulling the car back.
    Anyone got any ideas?? As I said before I have no idea what it is but it's almost like the car is cutting the fuel.
    All help will be greatly received.
  2. sportstractor
    sportstractor Chugger
    2,709
    Have you been able to have it scanned for faults? Also why are you running a MBC?
  3. Dani_B19
    9,161
    360
    Have you fitted the mbc right? And like said, why have you fitted one?
  4. Maccabee33
    20
    I only put it in to see if it would go over 5 psi as I thought it was odd that it's was only boosting at that.
    I have been doing more reading and I'm not sure if it's related to my maf as I have had to disconnect it because its faulty and haven't had a chance to get a new one.
    I haven't been able to have it scanned either I should be able to get my mate to do it at some point this week I hope.
  5. <tuffty/>
    20,995
    3,762
    If you have fitted the MBC without the car being mapped then its hitting limp mode... you cannot just fit an MBC on a std map... it simply doesn't work...
  6. Dani_B19
    9,161
    360
    So prior to fitting the mbc your car was only making 5psi?
  7. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,184
    Has this car been remapped yet?
  8. Maccabee33
    20
    No no remap it is planned. I wasn't using the MBC to gain more boost in that way just to see if it would go over 5psi and yes dani it was only hitting 5 iv not noticed any loss of power since iv had the car and it's always been the same ever since I put the boost gauge in
  9. Dani_B19
    9,161
    360
    Well that sounds like the cars running on actuator pressure, so either the n75 valve isnt plugged in or its knackered and you need a new one.
  10. Maccabee33
    20
    I did think it may be that but then loads of post say they don't fail that often. Iv tried running it unplugged and the same. I have also diverted it and it still only hits 5 I'll get a new one and try that. Is there anypoint getting a aftermarket one ? Iv seen people say not to.
  11. <tuffty/>
    20,995
    3,762
    First off... what engine code? what car? what year? difficult to begin to suggest anything without knowing...
    Reading back through some of your previous posts it seems you have bee hacking into various pipes to fit a boost gauge... did this problem happen before or after fitting the boost gauge?
    Have you put the N74 pipework back to how it was? from what I read you didn't connect it right... incorrect pipework on the N75 may well be the problem here if not..
  12. Maccabee33
    20
    No car felt the same before adding the boost gauge. All pipe work is completely back as before except for joining piece. With clamps. And boost gauge in. Correct place. Its a V reg I think 99. 1.8 t front wd 150bhp.
    Sorry I know you guys must be going bad about how car retarded I am. I work on tech support so I know the feeling and I apologise.
  13. Prawn
    11,443
    3,339
    seriously dude, you're asking about boost issues, and playing with an MBC, whilst all the time your MAF is unplugged?
    Why even bother asking for advice.....
    ''Guys, I have severe trouble walking, please help''
    ''hmmmmmmmmmmmmm, I can't think what your problem would be Sir, can you give us more information''
    2 hours later......
    ''oh, by the way, I've got no legs, don't know if this matters''
    Fix the known faults before trying to solve the unknown.....
  14. Prawn
    11,443
    3,339
    Sorry if that sounded arsey. it wasn't intended that way, but you'll never have any joy chasing problems if you have existing known issues in the first place.
  15. <tuffty/>
    20,995
    3,762
    All good bud... we all started somewhere :D
    If its an AGU then chances are the MAF is a little tired... the MAF's on AGU's control just about everything... I would grab a copy of VCDS or find someone that has it and get the car scanned for fault codes...
  16. 16Klappe
    5,795
    1,184
    I wouldn't worry too much dude, just stop doing things the **** bodging way and get it mapped properly from here on in. There are people who think they can do all this themselves, and it always ends in disappointment and tears.
    Take the MBC back off, get a new MAF and see if it still runs into limp mode. Then go and get it scanned properly, and assuming it runs normal with the MBC off and the fault codes removed go and get it remapped.
  17. Maccabee33
    20
    It was doing it before the maf was unplugged or had a problem. I totally understand I'm annoying myself on how little I know or I can assist
  18. 16Klappe
    5,795
    1,184
    Get a new MAF, if it was doing it before the MAF was unplugged...and the MAF was unplugged because it was faulty...and it's still doing it now without the MAF...you do the math. :icon_thumright:
  19. Maccabee33
    20
    Thanks <tuffty/> I saw a post today about cleaning the maf so was going to do that to see if it sorted it.
    It's odd that defore I had a problem with the maf it was still running at 5 psi. I'll have a look tomorrow and see what engine it is.
    Thanks for your help
    16klappe I'm going to don't worry! Just got the clear the bar tab first so I can pay for it ;)
  20. 16Klappe
    5,795
    1,184
    Out of interest, if you haven't got VCDS how do you know the MAF is faulty? Why did you unplug the MAF?
  21. Maccabee33
    20
    Car was cutting out randomly then got really bad and was stopping staring. Had my friend an actual mechanic have a quick look. Unplugged maf problem goes away. It was shutting its self off foursome reason. He said to get a new one just not had the chance and not going to lie wile it was running ok I have left it will get it sorted now I know how much it's controlling.
  22. 16Klappe
    5,795
    1,184
    And have you tried plugging the MAF back in? How do you mean "it was shutting itself off"?
  23. Maccabee33
    20
    Yeah as soon as I do the car won't start or if you have the car running it stalls when plugged back in. Not 100%as I'm sure is obvious haha. It closes the part inside ??? I assumed it was lack of oxygen. Wouldn't be suppressed if I was completely wrong
  24. Broken Byzan
    13,237
    465
    A duff maf can make the car chop out. My last one did it. With the maf disconected you'll be lucky to see 5 psi. Stick a new bosch replacement and your massive 8psi will be restored assuming nothing else is broken
  25. Maccabee33
    20
    Awesome thanks dude! I'll get that ordered up. Then I can start looking for some ware close to get a remap done.
    Any one know any in Hampshire/ Berkshire Basingstoke area ideally
  26. superkarl
    superkarl MAN OF STEEL
    9,423
    2,382
    Report back after a maf first! :) lol
  27. Prawn
    11,443
    3,339
    dude, did you want to try a different maf first and see if it helps things?
    I'm in Basingstoke, and have a MAF that's not being used until next weekend if you want to try it..... Could also plug it into Vagcom and see what's coming up.....
    Remap places close to you are Storm developments in Aldermaston, or JKM in Pompey
  28. Maccabee33
    20
    Awesome yeah that would be good! We're abouts in Basingstoke are you? Storm the guys that do the superchargers? They are just down the road from work. Perfect :)
  29. 16Klappe
    5,795
    1,184
    You can usually find him parked up just over the motorway bridge going up to Farley Mount, about 9PM on Tuesday nights. You'll know it's him because he'll have his interior light on whilst he reads the paper.
  30. Maccabee33
    20
    Yeah hooked the maf back up and no engine start. Took it off and had a look.... The sensor had half broken off god knows how but I'm defiantly off to get a new one now!
  31. A3AH
    A3AH Member
    364
    13
    ftr, when i changed my MAF sensor, i stopped going into limp mode.
  32. Prawn
    11,443
    3,339
    haha, thanks Jardo. charming.
    I'm in Hatch Warren mate, a few hundred yards from Sainsburys. What about you?
  33. Maccabee33
    20
    Oh right I think I know. Don't no Basingstoke to well only just moved here. Even though I did used to live in kingsclere I never really explored much. I'm up behind the station A couple of roads down from the vine ?
  34. <tuffty/>
    20,995
    3,762
    Google maps... its the future :)
  35. badger5
    9,423
    1,967
    AGU
    dont just up the boost
    not advised..
    get it remapped properly
    it will end in tears else
  36. Maccabee33
    20
    Thanks badger 5. That's what I'm planning on doing. Storm devopments are meters away from my work and have a deal on a stage 1 for £148.
  37. Maccabee33
    20
    Maf swapped much nicer but same problem. Put MBC in place of n75 as test and runs fine at normal boost. So of to get a new n75 now will post progress
