Car getting mapped in 3 week
s3gazz Aug 6, 2013
  1. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    Finally the car is getting mapped I'm taking it to rick at unicore let's see what the thing can give at last
  2. Gops
    3,198
    666
    Been a while ey gaz! You finished your build then?
    s3gazz likes this.
  3. azman
    azman Member
    58
    cheers for the head lights gazz, finally bought one to replace the knackered one fom you.
  4. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,262
    591
    I think we will have to give it a good check over first :) Should go well :)
    badger5 and Alex C like this.
  5. Prawn
    11,535
    3,475
    I thought it went for mapping at rtech long ago Gaz? More issues since? never finished?
    All the best with it anyway mate :)
    s3gazz likes this.
  6. Routledge
    Routledge Wind Deflector Trend-setter
    392
    10
    "azman has a little shameless behaviour in the past"
    I guess some things never change.
  7. azman
    azman Member
    58
    what you mean by this, for speaking up?
    only saying, i bought some face lift lights off gazz via ebay, went and got em, they had fly eye on them, removed it couple of weeks later to see one of the lenses was beyond repair, and had to replace it.
    but thanks for he negative princess :)
  8. s3gazz
    1,383
    105
    Azman I'm sorry about this my friend if I new about this I would not of sold them at all pal u should of contacted me mate and I'd of sorted it out .
  9. s3gazz
    1,383
    105
    ha lol nick no pal it's not been and had no money to get mapped but got a job now so more mods and see what this ***** finally makes haha
  10. s3gazz
    1,383
    105
    yes pal all done just need a new ecu I think rick is going to look in to this when I take the car to him.
    so what u guys think might be the outcome lol
  11. Andrew@A.L.D
    3,879
    617
  12. s3gazz
    1,383
    105
    Turbo spec is
    Compressor is a 2283 sized wheel but with a 7+7 blade design. Modified compressor housing. Custom made k16 sized turbine wheel 55mm/46.5mm . a ported and modified turbine housing. Upgraded bearing kit. 15psi uprated actuator.
    AGU head ported
    AGU pistons
    wmi kit
    v3 ported mani
    v3 3" ported downpipe decat and milltek
    Welly cooler
    550cc injectors
    inline fuel pump
    jetex
    dv
    power gasket
    v2 badger 5 tip
    I.E rifle drilled rods
  13. Andrew@A.L.D
    3,879
    617
    With the beach buggy turbo and everything is good then I would say you could hit the 300 mark
  14. s3gazz
    1,383
    105
    I hope so we will see large port inlet mani to go on and the new v4 mani when proven I'm saying 320 bhp owt above that is great for me more a less same spec as prawns so don't see why not lol
  15. Lemon S3
    Lemon S3 Alex
    1,390
    41
    I would hope you'd get well over the 300 mark. Going to say 333 :)
  16. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I would push it off the nearest cliff if it only made 300...
  17. badger5
    9,505
    2,003
    this would require an Actual Dyno not derived from airflow power Gaz
  18. s3gazz
    1,383
    105
    Yes pal that's what I'm thinking bill it's getting scrapped if it only make. 300 lol as Dave says off the cliff it goes
  19. superkarl
    superkarl MAN OF STEEL
    9,493
    2,436
    whats Dans thoughts of its capabilitiea? And k16 turbine in tiny ko4 housing. How does the k16 compared to the rs6 wheel thats commonly used?
  20. Prawn
    11,535
    3,475
    I was just about to answer this ^^^
    With this:
    I know mine was a freak, but if it only made 300 after that much work I'd actually burn it.
    A GOOD hybrid, PROPERLY built and specced can make 300bhp from just 1 bar of boost. Beyond that the limit is open for debate, but 320-330 seems to be the general area in which a good one should fall.
    Unless it's mine :laugh:
  21. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Definitely up around the 330bhp mark, but it needs a dyno as I can tell you that it'll flow 280grams on the maf easily and if you went off that alone its nonsense.
    It's also about not having the surge with these units making more drivable.
    Other than Gaz, Bill and 2 others these are the only k04 units with the k16 turbine. It works well in the Tfsi and in the k03 hybrid and hopefully in this as well, the question as always will be in the turbine housing limits it .
  22. s3gazz
    1,383
    105
    I think it will do great my self but that's me. Dan makes a great turbo so it can be done we will see in 3 week what's happens
  23. superkarl
    9,493
    2,436
    good luck anyway gazz, its about time you had a finished car so you can finally breathe again. its been nothing but trouble for you.
    s3gazz likes this.
  24. beachbuggy
    1,931
    201
    Plus it's running 300bhp in a small k03 Hybrid on a ermmm pretty worn engine:)
  25. s3gazz
    1,383
    105
    Thanks Karl it has been nowt but trouble lol your right there.
    Nice to no that dan hopes are rising haha carnt wait
