car getting lowerered tomorrow anything else worth doing?
pablo Sep 5, 2006
  1. pablo
    pablo Active Member
    985
    60
    Getting new shocks/springs fitted tomorrow by my local garage and was wondering if there is anything else worth replacing while its being done. bushes droplinks anything like that. Car has 87k.
  2. Tallpaul
    Tallpaul Member
    835
    topmounts, strut bearings, droplinks...
    Probably worth having them inspect the other ARB bushes while they are under there too...
    Problem is (and it's the same one i'm facing) most of the bushes 'could do' with changing, but parts and labour could easily add £300 - 400 to the bill :(
  3. pablo
    pablo Active Member
    985
    60
    I will swap for polyflex at some point anyway so no biggie there. Think Ill just tell them to replace anything that looks dodgy. I trust them enough not to rip the pi55
  4. Tallpaul
    Tallpaul Member
    835
    That's fair enough. Basically what i'm doing although i've already bought the topmounts, bearings and droplinks.
    I know something is a-miss at the nearside front because whenever i turn on to my drive i get a clonk noise from there, i've asked the mechanic to take a look and see if he can see anything obvious when he's replacing the shock.
  5. Defratos
    Defratos You’re Dethpicable!!
    2,232
    Do any of you know if they sell poly bushes for the ARB droplinks? or even aftermarket ones? cause VF does them for non 4WD cars and was wondering if there's one for a 4WD.
  6. fingermouse
    fingermouse thats me
    3,991
    111
    rear adjustable arms to set the cambre ????
    what suspension you gone for and how low ???
  7. dickys3
    2,954
    Remember to get 4 Wheel aliignment carried out also.
  8. pablo
    pablo Active Member
    985
    60
    koni - 20mm/15mm hoping to escape the need for adj arms.
  9. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    If you are replacing standard shocks and springs for uprated/lowered version, I'd get adjustable tie bars (required) and ARBs done at the same time - it'll save you a fortune in labour rates in the future.
    Depending how you drive and what you use your car for will determine how agressive you want you suspension/geometry settings. Negative camber of between 1 and 1.5 degrees all round is what to aim for. As for toe in/out it's all down to personal preference and how hard you drive the car.
    If using the car everyday or you don't drive it hard, I'd go for a parrallel setting. If you use your car as a weekend toy and/or drive it hard, probably best to dial in some toe out.
  10. cjhill
    cjhill hmmmmm interesting.
    335
    to ask a stupid question...
    what is the topmount ? where is it ??
    what is the strut bearing ??
    I know what the drop link - does the whole thing need replacing. I thought it was made of metal with rubber bushes at each end.?
  11. cjhill
    335
    is the topmount number 5??
    and the strut bearing number 6??
    If so, when you upgrade the shocks, do you still use original parts for these?
  12. Ess_Three
    Ess_Three Active Member
    5,383
    14
    Yes.
    Yes.
    Yes.
    :yes:
  13. cjhill
    335
    Many thanks,
    I think im starting to get the hang of this.
  14. fingermouse
    3,991
    111
    you getting excited there Glen ????
  15. Ess_Three
    5,383
    14
    Yeeeeeeesssssssssssssssssss!
  16. pablo
    pablo Active Member
    985
    60
    all done :) Nothing else needed replacing but they did say they didnt fit the koni bumpstops as they didnt sit as well as the audi ones
    well happy with the results :)
  17. cjhill
    335
    is that photo taken in Cardiff ??
  18. pablo
    pablo Active Member
    985
    60
    no mate belfast :)
  19. leecs3
    leecs3 thinking about stuff
    604
    which kit do you have?
  20. pablo
    pablo Active Member
    985
    60
    koni adj shocks and koni springs.
  21. Tallpaul
    Tallpaul Member
    835
    Looks good, although is parking it on the kerb making it look lower than it is?
    How many mm have you dropped?
    How much labour did the fitting take?
  22. pablo
    pablo Active Member
    985
    60
    20mm/15mm not actually measured it tho.
    it sits at about that on level ground too :) Just perfect!
    Cost me £100 for labour and a 4wa (to which they told me rear camber was off). Given the moderate drop on the rear Im just going to watch the tyre wear before shelling out £300 on adj arms.
  23. Tallpaul
    Tallpaul Member
    835
    My local guy want £194 for fitting and 4wa (inc VAT)...
    Be good to see a pic of yours on level ground, that photo looks lower than 20/15 - especially at the back :)
  24. Ess_Three
    5,383
    14
    It certainly does look lower...
    In saying that, H&R claimed a 20mm drop for the springs I had...which was actually 30-35mm as measured on the car.
  25. pablo
    pablo Active Member
    985
    60
    I dont know where they get some of their specs from defo more than 15mm at the back.
    love it tho :D
