Car flooding after mods
Neilybabs Aug 14, 2013
  1. Neilybabs
    Neilybabs New Member
    660
    10
    Hello peeps,
    I have a '98 A3 1.8T (AGU) that had a Jabbasport re-map a few years ago. All gravy.
    At the end of last week I picked the car up after having a Forge FMIC, Forge TIP and Toyosports 3" downpipe fitted. I also fit the S2000 cone filter mod and was left with what looked like an air flow sensor? So I zip tied it as close to the filter as I could. Happy days.
    I got about 10 miles and stopped at a junction and the car cut out. It seemed like it was flooded as it wasn't having any of it and stank of fuel. I went back to it a few hours later and it started first time and managed to get it home.
    I've bought a new K03s which I was going to sling on it before a re-map. Do you think the above is because I haven't had it re-mapped after the mods?
    Any advice is gratefully received as ever.
    Neil
  2. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Have you refitted the MAF (Mass Airflow Sensor) between the TIP and the filter? If not then you've left the engine without any idea of what air is coming into the system.
    Pics speak a thousand words, but this sounds like your problem.
    Neilybabs likes this.
  3. Neilybabs
    660
    10
    Thanks for your reply.
    I'm unable to get a pic at the moment but will try to as soon as I can.
    The MAF is definitely on the car. I'm wondering if some oil from the new filter or silicone grease has made it's way in there?
  4. badger5
    9,398
    1,943
    s2000 filter are dry
  5. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
    Mine was very lightly oiled and certainly not 100% dry when it was delivered from car parts 4 less.
    Think it's done to withstand moisture?
  6. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    As Bill says. S2000 filters are dry, they are a paper element.
    Fitting the mods will not have caused your issues. Fitting them badly will have.
    Plug into vcds and check for codes.
  7. kwistof
    2,434
    535
    The paper part of the filter was dry....but there was still quite a bit of oily residue in the packaging and around the plastic parts of the product.
    Far more than I was ever expecting...so went back and read through the S2000 thread and several other people have mentioned they found the same.
    Btw, OP I realise the MAF is on the car.... but make sure the MAFs electrical connector is properly plugged in and secure- should hear a 'click' to know it's securely in there.
    Next step would be to check for codes with VCDS as Jardo advised above.
  8. superkarl
    superkarl MAN OF STEEL
    9,398
    2,376
    make sure the maf is installed the right way round
  9. Neilybabs
    660
    10
    Thanks all for the advice.
    I don't have access to VCDS unfortunately, so can't give you any codes etc.
    I've had a word with the garage and I'll see if I can get it back to him, although i'm a bit wary of driving it as it cut out a second time when joining a roundabout. Great fun.
    Is it worth taking the MAF off and cleaning it?
  10. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Are you sure it's installed the right way round and the plug is fully clicked in place?
  11. Neilybabs
    660
    10
    I've just pushed the connector in and didn't hear a click. I took it off and pushed it back on again to be sure.
    I noticed a small black arrow pointing towards the TIP when I removed the connector. Is this the right way round?
  12. superkarl
    9,398
    2,376
    yes thats the right way
  13. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Did it drive fine before you fitted the filter? Just thinking that it could be downpipe/lambda related. Obviously fault codes would help.
  14. Neilybabs
    660
    10
    It did drive ok when I picked it up but I didn't really go any great distance.
    I've put the standard air box back on and it's stalled twice since. Wish I had the apparatus to supply the codes!
  15. Dani_B19
    9,103
    344
    Doesnt the agu have N ignition module that connects onto or into the airbox? Has this been disturbed or not fitted right?
  16. 16Klappe
    5,795
    1,183
    Yep.
  17. Neilybabs
    660
    10
    This must have been the bit that I took off when I installed the S2K filter then....
    I just had a quick look at this and the seal isn't complete where I've tried to push it back in. Booger. Could this be the route of all evil?
    What would I do with the ignition module if I wanted to stick with the cone filter?
  18. 16Klappe
    5,795
    1,183
    Just leave it plugged in and tuck it out the way, try ziptieing it to the bulkhead.
  19. Neilybabs
    660
    10
    So I guess the fact that it isn't seated correctly now isn't the main cause of the problems.
  20. 16Klappe
    5,795
    1,183
    Not going to help, but won't cause it to run as you have described.
  21. Neilybabs
    660
    10
    Righto. Thanking you Mr Jardo.
  22. Neilybabs
    660
    10
    Quick update. With the MAF disconnected it starts and runs. New MAF required. Coincidence I guess?!
    Once again, thanks all for the advice. Gotta love ASN. Love you long time.
  23. Neilybabs
    660
    10
    For info, if anyone is looking for a genuine Bosch MAF (Part No. 0280 217 117), try: www.germanautosupply.com. A US based company.
    The final price was about 110 notes (shipping included) compared to about 135 on a popular online auction site.
    JudderMan likes this.
