car feels underpowered
smokiedee Mar 9, 2012
  1. smokiedee
    smokiedee Member
    118
    had a remapped ecu fitted last week and the car pulled extremely strong in each gear but today it feels like a standard agu, and can hardly hear the dv at all. is it worth unplugging the n75 and seeing if that makes any difference?
  2. jay1601
    jay1601 Well-Known Member
    1,338
    70
    any fault codes?
    what boost are you making?
  3. smokiedee
    smokiedee Member
    118
    no fault codes at all and not sure as don't have a boost gauge fitted
  4. A3 Oly
    A3 Oly Member
    247
    this is probably way out of left field but it couldnt by any chance be a trial period map? what map is onthere
  5. smokiedee
    smokiedee Member
    118
    that's the first thing i thought too, i believe it's revo
  6. A3 Oly
    A3 Oly Member
    247
    how much actual driving time have u put in since having the map
  7. A3 Oly
    A3 Oly Member
    247
    if u have just gone over 5hrs then maybe it is?
  8. smokiedee
    smokiedee Member
    118
    i'm sure i've done over way over 5 hours
  9. badger5
    9,469
    1,988
    no trial version on AGU ecu;'s
  10. smokiedee
    smokiedee Member
    118
    that's good to know, getting looked at on tuesday
  11. R-Tech-Nick
    R-Tech-Nick Active Member
    150
    51
    The map might be in stock mode? If you have VCDS so a log on block 025 and see what load the map is requesting and post up your result.
    To swtich the map back on you need to find someone with the Revo SPS switch, a Forum member or a local Revo dealership.
  12. Heathie
    Heathie Member
    Have you tried cleaning your MAF Sensor (with a proper cleaning fluid)? I remap all Vag engines and the most common fault is the Maf Sensor, give it a good clean or replace it first.
