car cut out wont start :(
Cargo Oct 30, 2013
  1. Cargo
    Cargo Member
    32
    Was driving down motorway other day doing bout 60 put my foot down to pass a car
    And the car just cut out tryed starting it it starts but dies straight away the only light
    On the dash is the battery light.
    Went back to it yesterday started it it ticked over but wouldn't rev up after bout 2 mins cut
    Out with battery light on again
    Any 1 got any idea what it could b :(
  2. darren t
    darren t Member
    568
    could be the alternator?
  3. hades-
    9,481
    646
    id get it checked for codes
    even tho the eml aint on it may still have a code stored.
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Sounds like the crank sensor , need to scan for any codes really...
  5. Cargo
    Cargo Member
    32
    Will try and scan later when get home from work it will stay started if i keep the rev on but revs up n down then stalls if i let off rev or rev it to much
  6. aragorn
    18,545
    865
    Crank sensor seems likely, but check for codes.
    Battery light is normal so long as it comes on after the engine stalls. If its on with the engine running something isnt right.
  7. ticketyboo90
    ticketyboo90 Member
    30
    Just make sure you have fuel in before taking it to a garage and looking silly! I've had 2 a3's that said it was on quarter when the tank was dry as a pancake! Very unlikely but on off chance. Get some cables to another car and see how long it goes for. Leave the cables on for 10 minutes. If it's still running your alternators probley packed in! Or maybe your battry is goosed!
  8. Cargo
    Cargo Member
    32
    Ok up date i got my vcds out n turns out its out of date so wouldn't work changed crank sensor still doing the same. Thoght i had a break through when i unplugged the maf sensor it started running fine so went bought a new one changed it started running fine but had no boost seemed to just make the sound of an hoover but didn't go anywhere thought it mite just need resetting so took battery off for 5mins n now it wont start again anymore ideas trying to get hold of vag com to look for codes
  9. hades-
    9,481
    646
    so its a copy of vcds ?
    is the new MAF oem or aftermarket ?
  10. Cargo
    Cargo Member
    32
    Vcds was just a cheap one off ebay the maf was a oem bosch 1 from gsf would the maf stop the turbo spooling up? I have noticed the traction control light has come on but might b that i unplugged the maf to keep it started
  11. hades-
    9,481
    646
    no but the maf can cause problems but it would still boost with maf unplugged so cant be that
    it really needs codes reading to save spending on things its not.
  12. epox
    epox Active Member
    774
    74
    just replaced my maf as tc light was on , the car would not run at all with the maf unpluged..... also had to clear the ecu with vcds before the new maf would run correctly
    dont know if disconnecting the battery for 5mins would clear the stored faults.
    try downloading vcds lite again and c if it works,,,,,,,, daft question have you checked all boost...intercooler pipes are intact and connected?
    mark
  13. Cargo
    Cargo Member
    32
    Hi mark did your car stop boosting aswell b4 u changed the maf sensor.
    I tryed few things today but still no joy put the stock dv on swap the n75 valve then did the n249 delete checked all pipes look visually good no cracks or anything got a mate Cuming down tomoz with a diagnostic machine but not sure it gnna b any good as its just a cheap fault finder not vagcom or ross tech
  14. epox
    epox Active Member
    774
    74
    there was no kick in the back around 3000rpm, just when throught the rev range like a non turbo car.
    mark
  15. Cargo
    Cargo Member
    32
    Yeh sounds same turbo seems to whistle but doesn't go anywhere
  16. Cargo
    Cargo Member
    32
    Ok checked for codes it came up with maf sensor and check d.v cleared. Changed maf for new 1 replaced d.v with stock cleared faults both cleared traction control went off car wouldn't start after 10 mins of trying to start it started came up with maf again could i have a brand new dodgy part or do i need proper vagcom to clear this fault any help would much appreciated
  17. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    I would probably try using a genuine vcds cable. I think bez suggested this already.
  18. Cargo
    Cargo Member
    32
    He did pal just wondering if anyone new for definitely if i needed vcds or would i be wasting my money buying 1 just found this 1 would this do it
    Gumtree
    Thanks in advance
  19. epox
    epox Active Member
    774
    74
    looks like a chinese cable, did you try downloading vcds lite its free you would still need a cable under a tenner on ebay
    mark
  20. Cargo
    Cargo Member
    32
    Will try downloading tonight i do have a cable but not sure if it will work wat cable is it i need
  21. epox
    epox Active Member
    774
    74
    first one i used
    [h=1]VAG GROUP USB COM PORT OBD2 II KKL ECU DIAGNOSTIC CABLE LEAD WORK VCDS-LITE /409[/h]
    just do a check on ebay
  22. Cargo
    Cargo Member
    32
    Trying vcds light now an all its saying when clicking on read engine is no response from controller
  23. Scullies
    Scullies Well-Known Member
    1,543
    658
    Do you have the correct ftdi cable? No response is usually cable or ecu/fuse. Try turning the ignition on first, then plug the obd side in then plug the usb side it.
    Also have you set up the correct COM port in VCDS options?
    My money is on a big boost leak, like a hose has popped off or split.
  24. Cargo
    Cargo Member
    32
    Tryed it all ways mate im guessing my cables mite b a did 1 it says vag106 on side of it i cant hear any leaks or anything im hopeing that when i get a proper vcds that it clears the faults for gud puzzling me
  25. darren t
    darren t Member
    568
    have you checked the connector at maf common fail tuffty put a thread somwere lol not sure we're it is!
  26. aragorn
    18,545
    865
    Big airleak maybe?
    If it runs without the MAF and doesnt run with it, that suggests the MAF is feeding back incorrect info. This is sometimes because its faulty, but other times it can be because no air is flowing thru the maf due to a split pipe somewhere.
  27. Cargo
    Cargo Member
    32
    Wat like the actual connector or the wires mate
  28. darren t
    darren t Member
    568
    yes mate the pins inside connector come loose I had this problem fault was high signal input for maf! Mine looked ok aswell too be fair!
  29. Cargo
    Cargo Member
    32
    Worth a try thanks for ur help
    The car is starting now but traction control lights on n no boost when i clear the fault with my mate cheap ebay tool it wont start but traction control lights off then after a few mins of trying it starts then traction comes bk on this is with maf pluged in aswell
  30. aragorn
    18,545
    865
    Instead of just clearing them, why not tell us what the fault codes are?
  31. Cargo
    Cargo Member
    32
    Its just a cheap ebay tool all its saying is maf sensor to high but its a brand new maf did say check d.v but that's cleared andnot come back
  32. Vwdan80
    Vwdan80 Member
    100
    Could it be the tip is split in half down by the turbo sucking air bypassing the maf?
  33. Cargo
    Cargo Member
    32
    Fair point i will have a look i did take the tip off at the turbo end but didn't bring it up i was testing to see if the turbo shaft hadn't shaped all seems to b fine with the turbo it is a badger5 tip so don't tink it will have split but worth a try cheers
  34. Cargo
    Cargo Member
    32
    Ok got a code for u all any 1 got any idea wat it is its Cumming up pressure drop between turbo and throttle valve p1297
  35. darren t
    darren t Member
    568
    hole somwere between turbo and inletmanifold check all intercooler pipes and boost pipe too dv!
    Brundle likes this.
  36. Brundle
    Brundle New Member
    I no this an old post but new to all this and need your help!!! I'm having the same issue p1297 code and it's doing my head in boost come on at 2000 then of at 2500 then pops when I change gear then drives like an non-turbo car the other day the car die the Engine management light was going on and off then just stopped then wouldn't start then it did but died when Put my foot down. The car starting do my head in any help would be great Brundle
  37. Erikn89nl
    Erikn89nl Well-Known Member
    818
    327
    P1297 seems to be 'pressure drop between turbo and throttle valve'. Get your intake smoke-checked. Also, try using VCDS to check for more/different codes, as the generic ones don't always match.
    Brundle likes this.
  38. Brundle
    Brundle New Member
    Thanks mate what is a vcds? Dose it sound like it could be a leak do u think? Brundle
  39. Erikn89nl
    818
    327
    VCDS = VAG-specific software, used for many things, one of which is to read fault codes (also VAG specific)
    P1297: http://wiki.ross-tech.com/wiki/index.php/17705/P1297/004759
    Since it's a pressure drop, air is assumed to be escaping > leak. Also a very common fault on these cars, especially in the PCV system.
    Brundle likes this.
  40. Brundle
    Brundle New Member
    Ok thanks my mate just said he got vcds thing so hope I can get it sorted must be a leak some where. Under the inlet next to look and the pipe on top of the turbo hope I hind it .
