CAR BROKEN DOWN AGAIN!!!
AUDI TURBO Oct 7, 2008
  1. AUDI TURBO
    AUDI TURBO Member
    577
    This is starting to get so annoying after spending nearly 2k on repair this car cant it just leave my wallet be for a few months. and no it not a ecu fault (or petrol) driving home this morning and without notice revs drop completley battery light comes on. pulls over first thought alternator, belt etc battery loose...........nope all is fine so restarted the car and satrted fine no warnings or out so popped it into first brough clutch up and NOTHING i mean the clutch came all the way uo and the car didnt move. do audis work on clutch cables? has it sanpped?? I eman i knew my clutch was worn but it wasnt that bad. the car will satrt and you can hear a slight tapping noise like something loose or broken in the gearbox/clutch area?? any suggestions. going to scotland in 3 weeks and so far i had a new windscreen that WAS going to get done this week, front drivers seat loose so it rocks backwards and forwards and now this. :wtf:
  2. aragorn
    18,579
    868
    clutch is hydraulic
    If the engine is running and gear is engaged but there is no drive to the wheels then i'd have to say the clutch itself has gone.
    I've seen previously the center section can disintegrate as opposed to it just wearing out which might explain it going suddenly. If it was gearbox related i'd expect to hear a lot more mechanical crunching/grinding etc
    not sure why it stalled in the first place though...
  3. AUDI TURBO
    AUDI TURBO Member
    577
    THATS what i thought. now i know i can get clutch for about £90.00 but it goin to be a twat to fit isnt it?? i thought it could be clutch as it was near to the top any way. so is it worth buying uprated while im at it or just fit standard.
  4. AUDI TURBO
    AUDI TURBO Member
    577
    THIS CAR IS THE MOST UNRELAIBLE CAR IVE EVER KNOWN. GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR. i know a cluthc is wear and tear but my god the car has bin off the road more than on and even when on the road it still doesnt bosst/ or pick up the way everyone elses a4 seems to do. onestly my car was made by animals
  5. aragorn
    18,579
    868
    Not really looked into fitting a clutch, i'd imagine you're going to need to remove either the engine or the gearbox to do it though.
    Which is easier i dont know.
    I suspect that without the use of a garage lift and a tranmission stand/jack, removing the engine itself may well be easier than trying to remove the box from under the car...
  6. auroan
    auroan Active Member
    1,669
    My clutch is booked at a 7 hour job. Even a vw master tech I know who has his own unit with a ramp for weekend jobs didn't really want to entertain doing the work.
    It's probably a lot easier doing a 1.8T FWD compared to a 2.8Q.
  7. docurley
    4,073
    88
    [FONT=verdana, arial, geneva]A4 1.8Tq Clutch Replacement[/FONT][FONT=verdana, arial, geneva]xr4tic[/FONT] [FONT=verdana, arial, geneva]2004[/FONT]
    DISCLAIMER: This information is presented merely as a guide. Due to changes from year-to-year and options-to-options it may not be totally accurate. I can not be held responsible for anything that happens as a result of using this guide.
    This is not something that should be attempted by someone who has never worked on a car, or has little experience with them.
    If you use this guide, I only ask two things:
    1. Accept the disclaimer,
    2. Provide Feedback - comments/tips/problems/differences.
    There, now that that's out of the way, let's begin.
    Tools needed
    • Jack
    • Jackstands
    • Transmission jack - I borrowed mine from my uncle, it's from Sears, and has an angle adjuster and strap to keep the trans on the jack.
    • Impact wrench
    • 6mm allen socket
    • 7mm allen socket
    • 8mm allen socket
    • 6mm allen wrench
    • 8mm allen wrench
    • 10mm socket (3/8" drive)
    • 13mm socket (3/8" drive)
    • 15mm shallow socket (3/8" drive)
    • 15mm deep socket (3/8" drive)
    • 15mm wrench
    • 15mm "shorty" wrench
    • 16mm shallow socket (3/8" drive)
    • 16mm deep socket (3/8" drive)
    • 16mm wrench
    • 16mm "shorty" wrench
    • 17mm shallow socket (3/8" drive)
    • 17mm deep socket (3/8" drive)
    • 17mm impact socket (1/2" drive)
    • 17mm wrench
    • 17mm "shorty" wrench
    • 18mm wrench
    • 22mm wrench
    • 3/8" drive ratchet
    • 12" extension w/swivel end
    • 6" extension
    • 3" extension
    • screwdriver
    • phillips screwdriver
    • Torque wrench
    • Plug for coolant hose (I used a 3/8" bolt)
    • 6 point T40 Torx bit
    • 12 point T40 Torx bit - special tool???
    • Loc-Tite
    • Patience
    • Common Sense
    • fan (gotta keep cool, right?)
    If you're planning on changing the trans fluid, there are some special tools required. On my car it required a 17mm allen wrench (fill plug) and "3357 triple square socket" (drain plug) I bought the 3357 from http://www.zelenda.com and made the allen from a 17mm bolt welded to an old 1/2" drive socket.
    I, of course, had these sitting in my toolbox, in the back of my car, 180 miles away :( So I made a new fill plug remover by welding a nut to bolt, and using a wrench on the nut, which turned the bolt, which turned the fill plug. I then picked the trans up and drained it through the fill plug. I used Redline MTL (75w90) fluid, it takes 2.9 quarts.
    If you do change the fluid, do it after you're done. Wouldn't want to take the chance of spilling fluid in the area you will be working in/on for the next several hours.
    Parts
    • Flywheel
    • Clutch
    • Pressure plate
    • Flywheel bolts (shorter than stock bolts)
    • Pressure plate bolts (same as stock bolts)
    • Throwout bearing
    • Clutch alignment tool - not necessary, but helpful
    • Driveaxle or driveshaft bolts - in case you muck up the ones you have.
    • New lock-nuts for the turbo - Bentley manual says to replace them, I didn't
    • New drive axle and driveshaft seals - Bentley manual says to replace them, I didn't
    Instructions - Removal
    I am following the Bentley manual for the most part. There are some steps I skipped, some that need to be added, and others that can be done differently. I'm posting the steps and providing more info with them. If you are attempting this, you should have this manual already. It contains many other things, especially the required torque values for the bolts.
    1. Disconnect ground cable from battery - 10mm
    2. Remove driveshaft - ignore this step, it's not necessary
    3. Remove airbox - see pic
    - Disconnect MAF connector
    - Disconnect Power Output Stage connectors (see pic - 1)
    - Disconnect Solenoid Valve for Wastegate Bypass Regulator Valve connector (see pic - 2)
    - Disconnect EVAP canister purge regulator valve connector (see pic - 3)
    - Disconnect hoses
    - Pull airbox out
    My car has a custom cone air setup, which is why the POS is mounted on aluminum and bolted to the fender.
    4. Remove coolant tank and set aside
    - remove three screws from top (phillips)
    - Lift up and disconnect sensor from bottom (careful)
    - remove top coolant line and plug.
    - Leaving the bottom hose (big hose) connected, rotate the tank around about 135 degrees and lay it down
    Coolant tank sitting position and O2 sensor connectors.
    5. Disconnect second O2 sensor connector from under the coolant tank (leftmost connector - see pic) and free the wiring from any ties.
    6. Remove O2 sensors. The manual does not say to do this, but I did it. Trying to remove the cat is difficult enough without having to worry about breaking the O2 sensors too. Takes a 22mm wrench and a little elbow grease. You'll probably have to track down the connector for the primary O2 sensor, or you might possibly twist the wires enough to break them (mine didn't break, but the jacket/insulator on one wire opened up.)
    7. Remove nuts from cat-to-turbo connection. Three 17mm nuts. The shorty wrench will come in handy for the bottom nut.
    The nuts and O2 sensor have been removed
    8. Remove trans-to-engine bolts that you can get to from above. I think there were three accessible from above (left, middle, and right) 16mm.
    9. Remove engine pan/cover from underneath - 10 screws: 3 front, 3 back, 2 in each wheel well.
    10. Remove bracket for engine pan/cover - 2 bolts (13mm I think)
    11. Jack car up and put on jack stands. I'm not really sure of a good place to put the jackstands, I now have two slight dents in the floorboard of my car.
    Car up in the air. Possibly bad spot for jack stands.
    12. Remove heatshield from passenger side drive axle. Three 6mm allen bolts, two accessible with an allen socket (left and right) and the top bolt requires an allen wrench.
    13. With the car supported on jack stands, place slight pressure on the trans with a jack.
    14. Unbolt passenger side mount/support (leave mount connected to support) - two 13mm bolts, and three 8mm, again, two accessible with an allen socket (left and right) and the top bolt requires an allen wrench. Also remove the spring mount from the downpipe. You can let the jack pressure off the trans now, it will be fine without.
    15. Loosen clamping sleeve on downpipe-to-exhaust connection. You're supposed to be able to slide the clamping sleeves forward, but I couldn't get it to budge, and ended up pulling the downpipe out of it instead.
    16. Remove the cat/downpipe by pulling it out from under the car. I made the mistake of trying to get it out from the top. I did finally get it with a lot of swearing and fidgeting. Oh well.
    Catalytic converter and downpipe
    17. Remove RPM sensor from transmission. My car did not have this. If it did, it would be located on the driver's side of the transmission, above the flywheel (about the two o'clock position if looking at the front of the trans).
    18. Now the fun part (1st of many) Disconnect the driveaxles. The shafts are bolted in with six 12 point torx-head bolts. I was able to use a regular 6point T-40 torx bit to remove them, but I highly recommend trying to get the 12 point bit to reduce the chance of rounding one of these things off.
    19. Disconnect Speed sensor and reverse light connectors on driver's side of the trans. Make sure no other connectors are attached.
    20. Remove starter, two 16mm bolts and one 6mm allen bolt. The wires can stay connected. This can be done one of two ways: The long and painful way, or the short and painful way.
    - Long way: Remove bumper, remove A/C belt, remove A/C pump, remove starter.
    - Short way: Attempt to get at 6mm allen bolt with an allen wrench by maneuvering your hand and arm through the A/C lines. When finally out (wait until you have to put it back in) remove the two starter bolts, slide the starter forward and attempt to lay it aside somehow.
    21. Disconnect shift rod, one 10mm bolt
    22. Disconnect shift pivot rod - one 8mm (may have been 6mm, not sure) allen bolt. Space is tight requiring the use of an allen wrench. When it's out to the point that the allen wrench hits the trans tunnel, remove the allen wrench and try turning the bolt or washer on the backside with your fingers.
    23. Remove the heat shield for the driveshaft. My car did not have this.
    24. Remove the driveshaft from the trans - six T-40 Torx bits, let it hang on the heat shield.
    25. Remove the four engine-to-trans bolts on the bottom (all 16mm), and there should be just two left holding it together afterwards.
    26. Place transmission jack under the trans and put pressure on it.
    27. Remove driver's side trans mount-to-support bolt (8mm allen bolt), leave the support bolted to the trans.
    28. Remove the last two engine-to-trans bolts.
    29. slide trans and trans jack back just enough for the bell housing to clear the pressure plate.
    30. Lower trans just enough to get access to the clutch slave cylinder. While lowering the trans, DO NOT LET THE INPUT SHAFT HIT THE PRESSURE PLATE "FINGERS" The clutch cylinder is held in with a 6mm allen bolt, and will take a little bit of wiggling to get it out. Careful, it's made of plastic. Do NOT remove the line, and do NOT press the clutch pedal.
    31. Make sure all drive axles are clear of the trans and lower it. You might have to pull the trans off the jack to slide/drag it out from under the car, or you can just leave it under the car, and slide it out of the way.
    Empty trans tunnel.
    Parts removed
    1 - Passenger side trans mount and related bolts
    2 - Exhaust clamp bolts
    3 - Passenger side drive axle shield and related bolts
    4 - Starter Bolts
    5 - Engine-to-Trans bolts
    6 - Turbo-to-downpipe nuts
    7 - Exhaust hanger spring
    8 - Driveshaft bolts
    9 - Clutch slave cylinder bolt
    10 - Driver side trans support-to-mount bolt
    11 - Drive axle bolts
    12 - Coolant tank screws
    13 - Just a rag, ignore it :)
    Removing the clutch/flywheel
    1. Remove the six 6mm allen head bolts from the pressure plate and remove it and the clutch plate. A screwdriver might be needed to gently pry it off. Careful, the pressure plate is the only thing holding the clutch plate in, and it WILL fall if you're not paying attention.
    2. Bust out the impact wrench to loosen the six 17mm flywheel bolts. You probably don't need the impact, but you will spend a very long time trying to get the bolts loose without one.
    Installing the clutch/flywheel
    1. Look at the flywheel and you'll notice the bolt holes are irregular. The flywheel only goes on one way. when you have all 6 bolts in, torque them down. I held a screwdriver between a flywheel tooth and the block while tightening. The manual calls for 44 ft lbs + 90 degrees. The shorter bolts for the new flywheel probably don't require the 90 degree turn. Check with APR to be sure.
    2. Put the clutch disk and pressure plate on, the clutch disk has to go in a certain way (the taller middle side goes towards the pressure plate) Start putting the bolts in, but don't tighten yet. You need to center the clutch disk in the pressure plate. I eyeballed it since I didn't have the alignment tool. Torque the bolts in stages in a triangular fashion when it's centered.
    Time it took me to get this far, about 7 hours.
    Take a break, the hardest part is about to begin.....
    1. With the transmission on the transjack (if it has an angle adjuster, make sure it's on the correct side), slowly lift it into place, making sure that nothing is in it's way. You will need to match the angle of the engine with the angle of the jack. You will have to slide the trans in a little, jack it up, slide it in, jack it up, etc until the trans is aligned withe the engine. It may help to have a greater angle on the trans, and when it's lined up, equal the angles out. DO NOT LET THE INPUT SHAFT HIT THE PRESSURE PLATE FINGERS. If one of them bends, bad things happen.
    Jack on transjack - notice the the dents from the jackstands.
    2. Put the clutch slave cylinder back on. Trust me on this one, do it now, before the trans is connected.
    3. Now the fun part, inserting the trans. Mine slid right in, but if it doesn't, remember patience is the key. Put the trans in gear and try rotating the driveshaft end. this rotates the input shaft, and may help align it. If all else fails, pull the trans out (careful if the slave cylinder is bolted on), and check to make sure the clutch is still centered.
    4. The trans probably wont slide all the way in. Get it in enough to get a bolt started on either side (start with the bolts that go through the guide pins.
    5. Basically, everything else is the opposite of removal, just a little more difficult.
    Reassembly time, about 8 hours.
    Things to avoid (aka what I did wrong)
    1. Remove the cat/downpipe from the bottom. It will come out from the top with a lot of struggling, yanking, and cursing, or it will drop right out the bottom with slight maneuvering.
    2. when putting the transmission in, I got the shifter pivot arm caught between the trans and the hull, and bent it straight. I found this out after I had everything in, and realized I couldn't shift into 1st, 3rd, or 5th. The shift rod wouldn't come back far enough because it hit the shifter pivot arm. A jack and a 2ft long 2x4 promptly bent the arm back into shape :)
    3. I tried to put the clutch slave cylinder on after the trans was installed. I could not get it to compress enough to install. I had to crack open the bleed screw and then push it in (I had a hose and container hooked up to catch the fluid), and then bled the clutch system afterwards (not a big deal though)
    4. My APR flywheel/clutch was used and didn't have any bolts with it. I had to cut 5/8" off the end of the flywheel bolts in order to use them.
    Notes/Comments/Suggestions:
    Plan on a weekend for this job. Start Friday night, and if all goes well, you should be done Saturday night, or Sunday morning.
    I started Thursday night about 10pm, worked until the trans was out at 4am. I started again Friday night about 9pm, worked until 4am and finished up a couple little things Saturday afternoon.
    I should also say that my clutch and center Torsion were replaced about 10 months ago (25K miles) so I didn't have any stubborn bolts.
    You might want to start by trying to bust the driveaxle and driveshaft bolts loose first. These will probably be the toughest bolts to get out. If you can't get them out, there's no sense in continuing, and it would suck to have to put everything back together
    Some tips in case of a stubborn torx bolt:
    1. hit it with a hammer a couple times
    2. If it rounds off inside, try pounding an allen bit into it.
    3. You could try grinding a slot in it, and using a screwdriver.
    4. Try Vise Grips
    5. You'll notice that there is a connector between pairs of bolts. If it's the right bolt of the pair, you can use this connector as
  8. aragorn
    18,579
    868
    looking at that it seems to me that pulling the engine out the top would be a LOT easier... Perhaps its just me, but i much prefer working from above than rolling around on the floor under the car!
  9. Adam-D
    Adam-D Member
    457
    looking at that i do not wish to take my gearbox off.
  10. aragorn
    18,579
    868
    ye ours whines a little on overrun and the clutch is very high, it better not fail!!!!
    the Plan is to keep this car until Summer, at which point the missus will have finished uni and be working, we can then sell it and buy something Quattro! As such money spent on it it being limited to keeping it on the road, safe and legal!
  11. auroan
    1,669
    This is why I'm letting York Audi do mine for £600 all in.
  12. docurley
    4,073
    88
    Chickens....:haha:
    Ooops I got someone to do mine :blush:
  13. aragorn
    18,579
    868
    Lol at the chicken comment!:)
    My Landrover is currently in lots of small pieces and ive got an Audi V8 i will be attempting to shoehorn into it once i've started reassembling it onto a new chassis! :uhm:
    If the A4's box or clutch failed then by all means i'd be doing it myself, mainly due to the lack of any funds to pay someone else to do it! But until it does, it can stay how it is! :)
  14. AUDI TURBO
    AUDI TURBO Member
    577
    DAD works for vw so it handy but i cant wait to tell him that i need a clutch in my car. whoops
  15. AUDI TURBO
    AUDI TURBO Member
    577
    and aragorn thats what i hoped clutch high but hoped it wouldnt fail and it has :(
  16. AUDI TURBO
    AUDI TURBO Member
    577
    and on another minor point in comparison i hope the drivers seat easliy repaired
  17. AUDI TURBO
    AUDI TURBO Member
    577
    AND now the drivers seat not leans off the frame to nearly on the back seats......... great. PLUS just found out my car has a dual mass fly wheel and clutch £300.00 +vat jesus christ. 3 weeks before holls
  18. Adam-D
    Adam-D Member
    457
    the way audi prices keep falling, cost up a replacement and swap your bits onto it.?
  19. Siena
    Siena Active Member
    2,626
    I love doing clutches, rain, snow or shine.
    Can't beat the satisfaction of slamming the box back in from underneath, and putting the first bellhousing bolt in.
    I've never used a clutch alignment tool, unless my beady eyes count.
    Always removed the box too, as opposed to the engine.
    Your flywheel sounds an absolute killer - £300??
    I can do you a lightweight single mass one for a lot less.
    I can also do you a flywheel / clutch combo to upgrade to a 240mm one, your stock item's 228.
    Don't forget Audi have a surcharge on the old part, so it has to go back.
    And, don't be tempted to fit an el cheapo clutch, with the amount of work involved in replacement, false economy.
  20. Siena
    Siena Active Member
    2,626
    :laugh:
  21. Adam-D
    Adam-D Member
    457
    siena, i would like to know what i need to look for to check on my car to see if your 6 speed will drop straight in? somthing about doghnuts?
    and a price on the box inc postage aswell
    i cant sell my car so i might aswell make it how i want it
  22. Siena
    Siena Active Member
    2,626
    Adam, my 6-speed box has sold.
    But they come up every now and again, so let me know...
  23. aragorn
    18,579
    868
    Are all 1.8T's dual mass as standard?
    I've looked on vagcat and can only see one flywheel and 228mm clutch listed for the 1.8T and the flywheel seems to be dual mass...
    I had thaught some of them were solid? Is the normal approach to use a single mass flywheel off an older engine with its corresponding clutch?
  24. aragorn
    18,579
    868
    Hmm it seems that B6 A4's use a single mass unit, so i guess a flywheel from one of those and its corresponding clutch would do the trick?
  25. Siena
    Siena Active Member
    2,626
    All are dual mass, from '95 - '01.
  26. Siena
    Siena Active Member
    2,626
    As per a B6 item, I'm not sure if it's SM or DM, but from the price, I'd say DM.
    At it's current price - close to £450+VAT, you wouldn't want to go down that route either.
  27. aragorn
    18,579
    868
    can always look for a breakers though, unlike DMF's solid flywheels tend to be a bit more resiliant and a used one would likely be fine.
    I presume yours are aftermarket items?
  28. Siena
    Siena Active Member
    2,626
    Yes, mine are aftermarket lightweight units.
  29. AUDI TURBO
    AUDI TURBO Member
    577
    ok please HELP me on this. obv car going no where if i put car into gear and bring clutch up but the car goes no where. but if i push down on accelerator pedal the speedo registers speed???????????????????? WTF!!!! the car also making a regular tappign/knocking noise when running and get louder as the revs increase????
  30. AUDI TURBO
    AUDI TURBO Member
    577
    also the front drivers seat front bracket has broken. plus it got a large tear in seat so i think new seat time. any one got a front seat goin cheap??
  31. Turbo Lag FTW
    Turbo Lag FTW Hate those none insured you know who types
    235
    You sure you dont wanna buy a new A4 and transfer what youve got over lol, your list is gonna get bigger and bigger the way your luck is going.
  32. AUDI TURBO
    AUDI TURBO Member
    577
    worst car ive ever had
  33. Turbo Lag FTW
    235
    Mines the most reliable Ive ever had, I guess if I had the Audi 80 beforehand for a longer period of time it would just of been as reliable. I was accustommed to peugeots (Brakes are twats) so the reliablity issues are colossal lol. Oh btw the sig is class, shame you bought a dud.
  34. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    I think the speed sensor is on the gearbox, so that might suggest the gearbox is turning.
    Problem with the diff?
  35. Broken Byzan
    13,237
    465
    Then you have a driveshaft or CV issue. The inner joint could be unbolted, or the CV could have given up, has it been clicking when turning?
    Also as the speed is registering that would suggest its the OS thats gone IIRC
    HTH
  36. AUDI TURBO
    AUDI TURBO Member
    577
    yes got a clicking noise on turn over. just checked again got a loud noise and juddering and get louder as revs increase. if it the diff/gearbox it aint goin to be worth doing add that with the clutch and fly wheel mite aswell scrap the car
  37. Broken Byzan
    13,237
    465
    get someone tolook under the car at the driveshafts when you stick it in gear, it will be evident which shaft etc is turning. The diffs are pretty hardy in these, so i still suspect CV
  38. AUDI TURBO
    AUDI TURBO Member
    577
    it is NOT CV OR DRIVE SHAFT!!!!!! Def not. car on full stands and the it def sound the fly wheel or clutch or both shot to pieces.
  39. Broken Byzan
    13,237
    465
    SH*T !
    I would imagine you could DIY it in a day quite easily, especialy as you managed to do the oil pump, that is a harder ,more complicated job in my eyes
  40. AUDI TURBO
    AUDI TURBO Member
    577
    cv are not the problem. so time to price up clutch and flywheel. got a good price from siena. but dont know if worth spending the extra £150.00 on uprated parts unless im intending bigger BHP later on........which might just be on the cards. i really waat to get this car right. get it resprayed into the next year, new turbo, remap, fmic etc ive always wanted a turbo car bit more to play with. thats why got the audi. but it depends if it just keeps going wrong......... if i could get upto a decen 230-250 bhp for upto about 1K i proberly get the car fully repaired. i dont know though
