Car being a bit of a pig to fire up ( just the first time each day )
S3 Paul Jun 7, 2010
  1. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    Just of late my car has been a bugger to fire up , This only happens when the car has been left for atleast 6 hours ,
    Ive charged the battery and it isnt temperature ( weather ) related
    It turns over as normal just takes maybe a second or so longer than normal,
    Any ideas anybody??
    While playing with vag com ( no faults found ) i noticed the coolant temp. read on vag com shows around 100 degree and the dash shows 90. this surely isnt the problem is it??
    I mean a faulty coolant temp. sendor??
  2. Dani_B19
    9,046
    336
    Funny you'vw posted this as mines the same, thought it was the battery but had that replaced and its still the same, sometimes worse if its been cold, think it might be down to the MAF as i think thats knackered.
  3. sportstractor
    sportstractor Chugger
    2,709
    35
    Mine had a funny starting thing going on after it had a smoke test, so I changed the maf and it went away.
  4. sportstractor
    2,709
    35
    nah they do this down to the varible temperture readout, its to make the car look more quality than it actually is.
  5. finesse
    finesse Active Member
    2,805
    MAF Clean, I am about to do it now.
  6. Dani_B19
    9,046
    336
    Already done it, think the Maf is well an truely dead.
  7. finesse
    2,805
    Shout at it, usually works with most things!
  8. Westy
    Westy Well-Known Member
    17,442
    1,100
    I had issues in the cold but its gone now its warmer. I've replaced the temp sensor, replaced the fuel filter, cleaned the throttle body, reset the TB position, and cleaned the maf. It still does it in the cold!
  9. Dani_B19
    9,046
    336
    Its annyoing as hell, thinking about torching mine tbh at the moment and getting an s4 :)
  10. Westy
    17,442
    1,100
    I just have to rev the engine a bit when starting and it seems fine. Makes me look like a sodding chav though.
  11. Dani_B19
    9,046
    336
    You are though, arnt ya westle? lmao :)
  12. Westy
    17,442
    1,100
    How dare you! :(
  13. Dani_B19
    9,046
    336
    Haha, im only messing matey.
  14. S3 Paul
    2,823
    107
    Mine has a newish maf.
    What do you mean sportstractor? "smoke test"?
  15. Sandip
    2,438
    91
    Mines doing the same, quite bad after the car's been sat for a few hours. Sounds like a Subaru on start up for about 5 seconds. Starts fine once its hot though.
    Seems to struggle alot when the car is parked on an incline, it's starting to really piss me off:keule:
  16. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,126
    1,968
  17. Sandip
    2,438
    91
    There's one thing people haven't tried, the N80 valve, maybe i should give that a bash, might even change the fpr too, it's sounds like a fuelling issue on start up:shrug:
  18. Sandip
    2,438
    91
  19. Westy
    17,442
    1,100
    Nope! You've hurt my feelings now. Bloody Northern Chav :beee:
  20. finesse
    2,805
    ............lol
  21. Sandip
    2,438
    91
    Just to let you people know, i fixed my starting issue. I spent lastnight looking for what the hell was wrong, tested everything. In the end i ended up checking around near the pcv system and hey presto!!!
    There are 3 outlets on the left hand side on the intake manifold, 1 on the side and 2 underneath. The culprit was 1 of the outlets underneath. The pipe that goes to the FPR was rubbing on the pcv rubber sleeve and it had managed to make a tiny hole in the pipe. Whipped the pipe off, changed it for some Forge vac line and job done, car starts fine!
    I also had a mess around with the FPR before i found this split hose and it ended up leaking so went the eurocarparts and picked up a 4bar fpr, put it in today and the cars running spot on:)
  22. badger5
    9,365
    1,911
    same as reported by tuffty some time ago in his build thread
    all the same **** happens to these cars
  23. sportstractor
    2,709
    35
