cant open my bonnet
slight_problem Nov 8, 2007
  1. slight_problem
    slight_problem New Member
    27
    as above had a little dink last week and now i cant open my bonnet any ideas how i can open it with out causing too much damage
  2. andybnwc
    andybnwc Member
    752
    piece of wire through grill hook onto lhook on lever and pull unless it wont pop at all if not check the metal colar seat in the plastic handle hasnt come loose if yes hold plastic outer and pul metal cable with pliers
  3. Jimbo.King
    Jimbo.King Active Member VCDS Map User
    270
    50
    Pull the bonnet release from inside the car while someone else pushes and pulls slightly on the front edge of bonnet to try and release the catch.
