Can't get into car
02audis3 Oct 23, 2009
  1. 02audis3
    02audis3 Member
    133
    problem after problem:( im not driving car s3 till end of year so its sitting in drive a bit away from my home.
    so, my original battery went flat after 1 week of sitting there. i bought new battery was starting in roughly every 4 days,
    so today went up to car and fob didnt work my dash isnt lit up also so do you think its defo the battery?
    my key fob wont open the door or boot can i somehow get the bonnet open from underneath. :bye:
  2. <tuffty/>
    21,359
    3,926
    You could just use the 'key' bit... I know its 'old skool' but worth a try....
  3. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    Use the Key... old fashioned way... put it in door. turn.
    It will be the battery, mine did the same. dont try boot as they use micro switchs which obviously need power. pop the bonnet. your away
  4. 02audis3
    02audis3 Member
    133
    i have two keys that only open door and not engine well im hoping, my fob doesnt work opening the door prev owner changed locks, need to travel back home then head back to car and try, thanks
  5. 02audis3
    02audis3 Member
    133
    opened door with the stadard keys i have, and then alarm went off opened and shut door again then tried fob and fob works as normal weird.. does the audi dash stay lit 24/7 cause i thought it used to mine doesnt
  6. NHN
    29,352
    1,720
    Not being funny mate but didnt using the key even remotely (pun intended) pop up as an idea, lol, come on mate
    No the dash only stays lit when you either turn ignition on or when you press one of the stalks & even then when just a stalk pressed it times out if no ignition on.
    Give her a 10 minute start everyday to keep everything turning as such & a weekly run is also an idea as I did for my S3 when I was running the S4.
  7. 02audis3
    02audis3 Member
    133
  8. Broken Byzan
    13,237
    465
    TBH its not an S3 thing having door locks, i understand they have been around for a while. They put the lock on there so you can open the door mechaniclay should the battery die.
