Can't delete bluetooth contacts
dannyboy75 May 23, 2013
  1. dannyboy75
    dannyboy75 Member
    91
    Hi all
    Has anyone else had problems trying to delete/edit numbers from the Audi bluetooth phonebook? I can add them just fine, but if I try and amend or delete any, the bluetooth lady proudly says "Function not possible".
    I wondered if there was some sort of PIN code protection on it, but I've gone through all the settings and can't find anything. Google suggests I'm not alone, but I can't find a definitive solution.
    cheers
    Dan
  2. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Which phonebook are you adding them into? Bizarely the BT module has a separate phonebook to the RNS-E, so if you have to delete contacts the same way that you added them.
  3. NHN
    29,295
    1,701
    Yeap +1 if showing as contacts from your cellphone, then delete them via the handset, the directory option I never use tbh, I find it very longwinded & a pita.
  4. dannyboy75
    dannyboy75 Member
    91
    Thanks guys. To clarify, I could never get the phonebook on my iPhone to sync with the in-car thing, so it's not that one. It's just contacts that I've added by voice, using the 'Store name' command.
