cant connect to the ECU
GeoA3 Apr 13, 2013
  1. GeoA3
    GeoA3 Member
    85
    well suddenly my obd port is not working,
    when i connect the obd port to the pc i hear the sound that its connected but cant read .
    and the led function the controller not lighting also i tried two cables.
  2. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    Have you checked behind the port to make sure it's all still connected alright?
  3. Scullies
    Scullies Well-Known Member
    1,543
    658
    Check the fuse too
  4. GeoA3
    GeoA3 Member
    85
    which fuse to check?
  5. GeoA3
    GeoA3 Member
    85
    yes
  6. Scullies
    1,543
    658
    I can't remember off hand but it might be #10, something along the lines of engine management.
    Can you start the car?
  7. GeoA3
    GeoA3 Member
    85
    yes the car starts fine all ok no problems,
  8. Lewis583
    956
    91
    As said fuse is the first place to check. Do you have an aftermarket radio fitted?
    I'm on my phone so don't have access to fuse diagram but there definitely is one.
  9. GeoA3
    GeoA3 Member
    85
    I still cant fix this problem!!!
    I get this erros
    the problem started alone I didn't touch any wire or something it was work perfect
    yes I have aftermarket headunit but it did work smooth so its not the headunit
    any ideas ? maybe change the ecu? the car starts and drive like normal
    Uploaded with ImageShack.us
  10. epox
    epox Active Member
    774
    74
    have you tried changing the com port? could be windows is using com port 1 for somthing else.
  11. badger5
    9,575
    2,038
    sound more pc than car
  12. GeoA3
    GeoA3 Member
    85
    yes I did the com thing com 1
    the k line where it should be connecting?
  13. epox
    epox Active Member
    774
    74
  14. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    Just unplug from car and perform dongle check in the application
  15. GeoA3
    GeoA3 Member
    85
    I did the com thing
    @udi a3 what do you mean?
  16. @udi A3
    1,819
    197
    When you first install vcds you perform a device test, have you tried re installing
  17. GeoA3
    GeoA3 Member
    85
    Yes when i press test i get this error " port status ok . Interface not found"
  18. @udi A3
    1,819
    197
    Hmm buy genuine :)
    Audi Dynamik likes this.
  19. GeoA3
    GeoA3 Member
    85
    hmm is this a wire diagram for the obd port?
  20. basil brush
    basil brush Active Member
    526
    170
    43
    Try it on another VAG car !
  21. @udi A3
    1,819
    197
    I think your cheepo cable has failed on you try another cable or take it into a computer repair shop and see if they can check it out.
  22. GeoA3
    GeoA3 Member
    85
    I tried to connect to other car seat Ibiza 2013 and its worked so the problem is with my car.
  23. @udi A3
    1,819
    197
    scrap it :D
  24. basil brush
    526
    170
    43
    That makes me the winner , what's my prize ?
    :D
  25. GeoA3
    GeoA3 Member
    85
    I did the k line test and its fine not the k line im take it to the garage I hope the can fix it.
  26. GeoA3
    GeoA3 Member
    85
    an update
    i just tried anther something
    i disconnected the battery for about 3-4 hours and reconnect . and its work nowwww :jump::w00t:
