Cant believe it
IrishDave Apr 10, 2013
  1. IrishDave
    IrishDave Active Member
    682
    45
    F**k F**k F**K. Started the engine this evening and instantly there was a horrid sound from the engine. Turned off the engine imediately. But the damage has been done. Looked down into the cylinder with a camera and there is a small piece of metal which has scored the piston face and cyl wall. I guess this means the cyl has to be honed to get rid of the scoring. Any advice.
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Thats very unlucky, sorry to hear your bad news. On the bright side its a good excuse for more mods. Can you Bore it out for larger pistons?
  3. Andrew@A.L.D
    3,879
    617
    bad luck mate
    depends on how deep the score is, but if its light they can be honed out if not its a over bore job
  4. Buzzer
    Buzzer Member
    410
    14
    Bad luck Dave. Anybody sorted for doing that type of work on it?
  5. Westy
    Westy Well-Known Member
    17,443
    1,105
    Bad luck. No other noises or warnings before this happened?
  6. IrishDave
    682
    45
    It will be me doing the work as I cant afford to pay anyone, except to get it re-bored. Oh the joys of car ownership. No other noises at all. The car had only been parked up for about an hour or so since I last drove it.
  7. Scullies
    Scullies Well-Known Member
    1,543
    658
    :blownose: Sorry to hear your bad news. Do you know what the pieces of metal is? Broken piston/broken valve ?
  8. IrishDave
    682
    45
    No idea where its from/off. Its only a very small piece. When I get the head off I will know more.
  9. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Unlucky mate, it can only be a valve bit? or even worse and more expense... a piece of turbo...:unsure:
  10. Andrew@A.L.D
    3,879
    617
    It could be even the ceramic of the spark plug that has broken off?
  11. IrishDave
    682
    45
    Got the piece of metal out of the cylinder this evening. It is only very small and is semi circular in shape. If it was a full piece of whatever it is off it would be no more than 2-3cm in diameter. It is dark grey in colour, best way to describe it would be a dirty piece of lead. Any ideas as to where it might have come from. Gonna do a compression test tomorrow or would anyone advise against this, before I take the head off for closer inspection.
  12. s3dave
    10,110
    736
    :sign_pics:
  13. IrishDave
    682
    45
    I know a pic would be much better. Will have to wait till tomorrow to get one.
  14. Dani_B19
    9,365
    400
    Valve?
  15. IrishDave
    682
    45
    Hope not.
  16. s3dave
    10,110
    736
    Was it Magnetic?
  17. IrishDave
    682
    45
    Yeah it was as that is how I got it out.
  18. s3dave
    10,110
    736
    May be lucky on turbo bits then, they will be stainless/ali ? ,,, non magnetic
    Taken the plugs out yet?
  19. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    i hope im wrong but it does sound like a bit of valve, a compression check will throw light on whats happened, the good news is exh valves are £11 each and inl £9 each, elring head gasket £20 and bolts £17, so 'if' there is no bottom end damage it may be poss to fix it for around £100, if your handy with spanners and have a spare 6 hours
  20. Prawn
    11,641
    3,636
    Is there a 'post of the year' award? If so, I think Dave just won it with this beauty :)
    how else do you think he's had a camera inside the bore David, and fished the offending chunk out with a magnet? :laugh:
    sounds like part of a valve to me, although it can't be 2-3cm in size, that's not tiny, that's enormous!
  21. s3dave
    10,110
    736
    Biatch...
  22. smurfworth
    smurfworth Well-Known Member Audi S3
    1,949
    548
    The key word was "if" there Prawn, not had your ultimate man fuelled breakfast to wake you up this morning? :p
