  1. Dom Knight
    Dom Knight Member
    53
    I have a canbus system on my bike, so I know that previous faults when repaired, you have to reset the canbus system memory values to zero or the canbus just keeps saying that the fault is still there.
    So I am assuming that as the canbus said that the car's hatch was still open when in fact it was locked shut that I will have to get someone to reset the canbus on our car.
    What do you think ?
  2. Lewis583
    956
    91
    Canbus is just the communication protocol that allows the control units on a car to talk to each other. I think you mean fault codes.
    If there is a fault code stored for boot hatch lock switch position open circuit/plausibility and you have had the switch repaired/replaced, then yes the fault code will require clearing with the use of a diagnostic system. VCDS for example.
    The lock switch doesn't always log a fault code though. So if the car still reports that the boot hatch is open when it is shut, and the switch has been replaced with a new/known working lock switch and there are no fault codes stored. Then I would be checking the wiring to the switch. Particularly around where the loom goes from car body to the hatch.
  3. <tuffty/>
    21,140
    3,828
    The boot switches (and the door switches for that matter) are a common fault... most of the time they don't register that the door/boot is open..
    8L cars use K-Line communications by the way :)
  4. Dom Knight
    Dom Knight Member
    53
    Hi guys.
    I went outside with the workshop book and followed the steps on how to refit the rear hatch lock
    And now I can say the light for the tailgate goes out when the car ignition is turned on.
  5. anderswhk
    anderswhk Member
    216
    So, i have me an A3 8L from 2002. 1.8T. No idea if its an Ambiente or Ambition model. Have anyone found out a sure way to tell if it has canbus or not? I an trying to install aftermarket HIDs. Mostly info i find by using google is in german.
  6. <tuffty/>
    21,140
    3,828
    8L comms are K-Line and only use canbus for the instruments/radio..
  7. anderswhk
    anderswhk Member
    216
    Thank you tuffy
