Can you turn it off
fossie Dec 19, 2012
  1. fossie
    fossie Member
    207
    The low level brake light came on the dash today. I aim to get them changed in the new year however the light annoys me. Is there any way to turn it off.
    Regards
    lee
  2. gary3306
    gary3306 Active Member VCDS Map User
    989
    40
    Not without VCDS
  3. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,053
    69
    Even with VCDS you couldn't disable the warning. You'd just clear the fault code but it would re-appear as soon as it detected the fault again... which, unless it's a faulty sensor, would be straight away...
    I think
  4. GarJE
    GarJE Member
    34
    Cut the wire running into the back of the pads and short them together/secure safely.
    Wearing the pads down cuts through an embedded wire which then triggers the warning.
    G.
  5. fossie
    fossie Member
    207
    What do you mean short them. Do you mean cut the wire coming from the pad and connect it back to where it plugs in from the loom? Like looping it back on itself so to speak
  6. claudefrog
    claudefrog Member
    372
    How about just put in some new pads? saves all the messing about with fooling the brake pad wear sensors :)
