Can you take key blade, swap transponder to new shell?
p1tse Mar 20, 2014
  1. p1tse
    p1tse Member
    796
    24
    Is it possible to get a new key so that can swap over key blade, transponder, rubber button on remote fob so to make it look newer?
  2. BakPak
    BakPak No Gear
    957
    137
    43
    I'm sure someone on this forum has a b7 key fob configured to work with his b6.
  3. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    I have a B7 fob working with my B6. You have to have the right version of B7 Fob, the glass immobiliser transponder capsule has to be be transferred and then a new blade has to be cut as the B7 version is a different size to the B6.
    Once that is done you have to re teach your car all your remotes available with VCDS
  4. p1tse
    p1tse Member
    796
    24
    Sounds too painful for now moving over to the b7 fob, but can it be swapped round to new b6 case, ie is transponder ok to remove and touch
    Can the key be swapped around?
  5. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    Yes is can be done.
    if its your only key i strongly advise against removing the transponder, if it breaks your car wont start.
    Pm me your reg and chassis details if you would like a quote for a complete new spare key.
  6. p1tse
    p1tse Member
    796
    24
    How fragile are the transponders or sensitive to being touched?
  7. Chrismawa
    Chrismawa Active Member
    457
    46
    Yep can be done, did this on my MK4 Golf. Was pretty straight forward.
  8. @udi A3
    1,819
    197
    They are glass and usually bonded in...
  9. p1tse
    p1tse Member
    796
    24
    Just had a look on youtube
    Seems straight forward enough
    Any b6 owners have the key fob with the chrome bottom edge?
  10. craigynett
    craigynett Member
    294
    10
    most people use nail varnish remover to soften the glue so the transponder can be easily removed. A new case will cost you a few quid off Ebay. Just make sure you buy 1 that holds the correct type of battery
  11. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    1,926
    199
    I've done both my keys to B7 ones, i found the best way to remove transponder was heating with a heat gun and then simply popped out with a pick tool underneath, just a quick one to note,if you do decide on the B7 route not all ccm's are compatible, i had to put a later version one in mine but all in all a straight forward mod.
  12. craigynett
    craigynett Member
    294
    10
    only 1 certain part numbered B7 remote will work with B6 but only 2002-04 B6
  13. mattyboyc
    1,926
    199
    Mine is an 02 and needed a later ccm, i replaced it with one ending in BD.
  14. craigynett
    craigynett Member
    294
    10
    yours is right on the changeover year then
  15. mattyboyc
    1,926
    199
    I have a great write up on this mod from Audizine in my subscribed threads but can't seem to post a link to it from my phone.
