Can you retro fit auto boot opening?
razza1 Mar 18, 2009
  1. razza1
    razza1 Well-Known Member
    3,069
    822
    It's a little thing that's annoying me, and it's only a £30 option when new, can you (or a garage) retro fit the automatic boot opening mechanism? It'll be more important when I've got the little one with me and therefore easier to press a button and not have to try and juggle things to lift it myself.
  2. Issac Hunt
    1,162
    Yes if you have the saloon?
    You need 2 new boot hinges and the springs for each side. About £130 in parts + the new hinges may need painting.
  3. razza1
    3,069
    822
    Have the saloon, it has the remote unlocking already which opens the boot ever so slightly but it doesn't spring open wide. Do I just need the springs then? If so what's the part numbers and price?
    If it's the £130 mentioned above then I'll forget it, thought that since it was only a £30 option then it wouldn't be too expensive to do retrospectively
  4. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    How about the Avant? Is it possible on that?
  5. auroan
    auroan Active Member
    1,669
    If you had springs strong enought to lift the avant lid, you'll most likely be launched 20 foot from the car when it opened.
  6. razza1
    3,069
    822
    lol! Do I need just to add the springs then, I'm not bothered about it closing automatically, I'll have a free hand by then, it's just the opening part...?
  7. auroan
    1,669
    from what I understand the uprated springs fasten to the hinges in a different way (which are also different) And ... but I'll need to confirm this... I think the uprated spring hinges mount to the body in different posistions to the std spring/hinge combination
  8. razza1
    3,069
    822
    bugger.
  9. auroan
    1,669
    right a bit more digging and I think all you need it the following;
    4F5827665A x 2 (springs)
    8E5827552K x2 (Struts - different gas pressure to std struts)
    8E5 827 302 RIGHT hinge
    8E5 827 301 LEFT hinge
    No change in hinge mount point
  10. razza1
    3,069
    822
    and prices please :) although I suspect it's as Isaac mentioned below... maybe a scrap yard is a better bet...
  11. Issac Hunt
    1,162
    I doubt you'll find them in a scrapyard but you never know I guess! £30 when ordered new was a bargain!
    IIRC the struts were £25 each and the hinges about £40 (+vat) I cant recall if the hinges come painted but I very much doubt it.
    It only opens the boot though - there never was an option for it to be closed automatically.
    IIRC the option was saloon only on the B7. Maybe with a lot of work you could fit the electric openers from the C6 A6 Avant onto the B7? Never seen it done yet though....
  12. razza1
    3,069
    822
    Maybe I read it wrong, I'm sure when I checked the parkers spec for the B7 it had it as an optional extra which was only £30. Clearly that would save the cost of the normal struts and hinges and would only be the difference in cost between the two.
    It's the new models that have automatic opening and closing according the audi website, so wondered if it was the same for the B7, obviously not.
    Thanks guys for your help and the info around this :thumbs:, but it looks too expensive for a nice to have. I'd rather put that towards a remap.
  13. Issac Hunt
    1,162
    Yup it was a £30 option. Audi option prices dont always relate directly to the value of the extra parts fitted though.
  14. PetrolDave
    1,559
    85
    Prices of options like this are, at best, the DIFFERENCE in price between the parts that are normally fitted and the parts for the option.
    For example, IF the price of the normal struts = £200 and the price of the option struts = £230 then the price of the option could be £30, but it would cost £230 to retrofit it.
