Can you repair a leaky EGR ?? TDI Forum included
ruffrida Jul 27, 2012
  1. ruffrida
    ruffrida Well-Known Member
    1,926
    313
    Hi Ya'll,
    I have noticed a bit of oil coming out of the hole in the bottom of my EGR.
    After a few searches i have found out this may cause limp mode, can anyone else confirm this??
    And if so can it be repaired or do you just have to replace??
    Also the car is revving up & down alot, like an auto choke. It also tries to run away with its self when cruising at low revs, or no revs at all. Where as a normal car would try and stall, this feels like when it gets to stalling it revs up and off it goes..
  2. ruffrida
    1,926
    313
  3. s17atw
    s17atw Member
    43
    Hi, I have changed lots of egr valves due to the oil leaking from the breather hole in the casing but I have never had one cause any other issues.
    Have you had the car long as these engines don't stall very easy and will drive on idle in lower gears , just asking as when we had customers buy a tdi after having a td or a petrol vw / Audi they said the car was running away with them .
    Is your car hitting limp mode??
    Why was the turbo replaced a few months ago ??
  4. Cobra88
    Cobra88 Active Member VCDS Map User Audi A4 Audi Avant Owner Group TDi
    553
    70
    Hi mate
    What tdi do you have
    if its a 90, 100, 110 or 115 i have an allard egr delete kit im about to stick in the classifieds's
    Ignore that stuff on the us forum as its ****
    you will always find oil in the intercooler and pipework as the breather chucks it in there and it wont cause a runaway.
    Regards
    Rick
  5. s17atw
    s17atw Member
    43
    Spot on , if you take off a lower intercooler pipe off a tdi motor there is a good chance that oil will run out of the pipe work
  6. ruffrida
    1,926
    313
    Yeh had the car about 18month, but have had plenty of TD's before, just seems to runaway a little more than usual, might be me.
    Turbo was reconditioned due to the vaines been seized as the car was stood for 6/8 months in the worst weather conditions possible.
    Car is going into limp mode under extreme load (motoways, going up a hill) that kind of thing
  7. ruffrida
    1,926
    313
    How much do you want for the EGR delete kit, as mine is a 110 and been looking at doing this rather than replacing the EGR, pm me with your price
  8. Cobra88
    553
    70
    Replied via PM mate
    knock a fiver off if your going to AITP and i'll bring it instead of posting ;)
    Regards
    Rick
  9. ruffrida
    1,926
    313
    Wish i was going AITP fella, and need it a little sooner than that, pm ya back
  10. ruffrida
    1,926
    313
    EGR Delete fitted (nice 1 cobra88)
    Runs really well until a hill or motorway, then limpmode not happy
  11. Cobra88
    553
    70
    Hi mate
    You tried adjusting the actuator .?
    I recon one turn to lengthen it and you will be there
    mine was setup wrong as where 2 i fitted for others recently
    Regards
    Rick
  12. ruffrida
    1,926
    313
    Eh up bud,
    You heard from Danio today?
    Would that be 1 turn down or up?
  13. Cobra88
    553
    70
    No not heard from Damien :(
    You need to lengthen the actuator rod to stop the overboosting
    Loosen the locknut
    then remove circlip
    pull off of vnt lever
    unscrew the rod one turn then put it back on the lever
    replace the circlip
    Tighten the locknut
    Take it for a test drive and try 3rd or 4th at low revs & high load
    Regards
    Rick
  14. ruffrida
    1,926
    313
    Nice 1 bud, will be on this tomorrow, let you know.
    Wil be seeing Damien on sunday (if this dont work) Saying that i wouldnt mind to see what live data it is running.
