Can you help-vag fault codes?
vw754 Dec 25, 2007
  1. vw754
    vw754 vorsprung Durch Technik
    2,352
    58
    Found on 2002 vw passat tdi vag-code= 01336 and also 00476.
    Any ideas? Origionaly the brake lights stopped working and 'abs,glowplug light,started to flash,now the brake lights work ok (same switch taken out,cleaned put back)
    Glow plug light is still flashing (abs one has gone off)no other faults apart from ones stated above. Been on the wikki site but had no luck......one code is on the site,the other is not. The one thats on there,i dont quite understand what its telling me.
  2. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
  3. vw754
    2,352
    58
  4. Sebastian
    Sebastian Member
    286
    Maybe you should start posting complete information, the fault codes you posted as well as the information about the car is incomplete.
