can you help im new on this forum
jonesywales Jan 21, 2012
  1. jonesywales
    jonesywales New Member
    hi im new on this forum. i hope you lot can help me. i own an audi a3 2 litre 170 bhp. a couple of days a go i got an engine management light. i pluged in my obdi reader and it poped up with the fault code exhaust pressure sensor circuit high input fault code:po473. the car is an 08 plate with a diesel particulat filter(DPF). i took it to my local machanic and he said it was due to the DPF since then ive taken it on multiple regen runs but to no evail. im wondering if its worth sorting this fault or just rip the dpf out? CAN YOU PLEASE HELP
  2. jessie123
    jessie123 Member
    90
    welcome jonesywales
    i had the same problems on my 170 quattro i changed eps on the back right of the bulkhead a day later dpf light came on took it on the mway like it says in the book then went into limpmode so would not regen done dpf delete and remap by a guy called clive.there is a secondary eps at the left hand side of the bulkhead by the silver heatplate check that one aswell hope this helps ps im in wales to
  3. jonesywales
    thanks mate ill take a look see if that sorts the problem out
  4. NHN
    29,577
    1,779
    Get someone with vcds or vas to do a force regen to see if it clears up.
  5. jessie123
    jessie123 Member
    90
    hey jonesywales
    any luck with your car yet mate
  6. jonesywales
    Replaced the sensor on my car today. i also reset the fault code and forced a regen. i took it for a good long blaast today on the motorway all the way from wrexham to anglesy and everything seems fine. thanks jessie123 for your help its greatly appriciated.
  7. jessie123
    jessie123 Member
    90
    no problem mate glad to hear its back to normal enjoy:yahoo:
