Can you get replacement front hub bushes....
TYphoon GB Oct 16, 2012
  1. TYphoon GB
    TYphoon GB Active Member
    386
    26
    Seems the inadvertently came out with the ball joints.
    Got two mangled ones so can't pop em back in.
    Its the bits that should stay in the hub...but are sized on...
    Anyone?
  2. Bit confused to what you mean mate, that pic is a lower arm, but there is no 'bushing' i know of just the machined taper in the hub that the ball joint fits into?
  3. TYphoon GB
    386
    26
    Ahhh but the pics doesn't show the taper. The bit over the taper is the soft metal bush from the hub that the ball joint sits in!
    Here's where the bushing should be...
    Had to lift a set from another hub and press em back in.
    Oh and no one does replacements.... a market for a self lub bush that makes removal easier me thinks.
  4. Broken Byzan
    13,237
    465
    Yep part of the upright only. Common for them to stick sadly
  5. Glad they stayed in when i did mine then, that would have been the final straw "fetch the petrol and matches please love":banghead:
